I see. There is a mistakes. Too late for correction. New post corrected.
First letter is the number of the procedure
Second letter is L or R and is Left or Right channel on the board GWH-146.
EXAMPLE:
AL-procedure A for Left channel
AR- procedure A for Right channel
AL-VR3 30kOhm (R47=1V) ,VR1=0
AR-VR4 30kOhm (R48=1V) , VR2=0
BL - VR 1,2,3,4 = 0 , R47=2,5V ,Q13C=1,781V
BR - VR1,2,3,4=0 , R48=2,54V , Q14C=1,753V
CL - VR1=0, VR3=max=79,4V
CR - VR2=0 , VR4=max=81,5V
DL -VR3 30KOms( R47=1V) , VR1=0 -this is done already in AL
DR - VR4 30KOhms (R48=1V) VR2=0 -this is done already in AR
EL - VR3 (R47=1V) ,VR1=0,150V (23,5Ohm)
ER - VR4(R48=1V) VR2=0,150V (23.5 Ohm)
FL - VR3(r47=1V) ,VR1=0,300V
FR - VR4 (R48=1V) , VR2=0,300V
GL - VR3(R47=1V), R1=0,450V ……….6.62V on R1 150 ohm
GR - VR4(R48=1V) , R2=0,450V……….6,06V on R2 150 ohm
Indications of the schematic of the measurements:
1- Q13C/Q14 C red to GND black
2 - Q15C /Q16C red to GND black
3 - Q17 E /Q18 E red to Q21 E /Q22 E black
4 - Q17C /Q18C red to Q17E/Q18E black
5 - Q21E/Q22E red to Q21C/Q22C black
6 - Q25E/Q26E red to GND black
7 - Q25C/Q26C red to R71 /R72 black
8 - Q27C/Q28C red to R71 /R72 black
9 - voltage on R47/R48
10 - voltage on R101/R102
11 - voltage on D11/D12
12 - voltage on D15/D16
13 - voltage on D13/D14
14 - voltage on R103/R104
15 - voltage on D17/D18
This is the best I can do for the requirements in #155 and #168 combined. We have 15 measurement methods that vary in 12 different ways. What I have added in addition, but it is necessary for more accurate statistics, is the right channel indexed with R. There I hope I have not confused the transistors, because I have simply used the mirror symmetry and the system of their designation as everything in this amplifier which is for the left channel is marked with an odd number and everything for the right channel with an even number.
I haven't made this chart since the first time. I made more than 6 different variants, including 3D graphics, but of all the variants, this is the most compact and the easiest to understand if you read the instructions carefully. In total I have made over 900 measurements of which I have published here in this table only 180. The reason for this is that the measurements have to be made all at once for a very short time without interruptions because the system is constantly self-regulating around some equilibrium and the data is affected by lots of factors likes the mains voltage, which varies, the thermal drift of the transistors.
Also my hand over the board which has capacitance and the amp picks it up and interferes which immediately raises the voltage on Q13C/Q14C. For this I had to ground my hand with a wire to the heater. Several times my probes slipped on the solder joints and shorted between the legs of the transistors, but there was some protection left to work and the amplifier did not burn out. That was the main reason why I liked that scheme better.
Finally, after a lot of practice, I managed to measure all 180 measurements at once, and I am posting them here in the hope that they will be of some use.( Still no answer from markthefixer should I do the last measurements with VR1/VR2=max and R47/R48=1v)
The measurements are accurate and the chart works.
Type designation likes this:
7 - Q25C/Q26C red to R71/R72 black means the following:
Q25C red to R71 black and Q26C red to R72 black.
This analogy is followed in all such notations with a slash "/"
