Running 4ohm speakers on a Sansui 1000A
sanford12
Old Stuff New Stuff As long as it's Good Stuff
I'm wondering if 4ohm Advent The Small Loudspeaker can be run with the 1000A. There is no 4ohm tap just 16 & 8. I would really like to hear these with tube power but I don't want to do any harm. Thanks
Sure, I'd use the 8, but be aware that it will change the primary Z of the OPT to some degree. Probably not enough to mess anything up, but you may want to check plate current if you plan on using them a long time. Just looking at the outputs for signs of pink or red in a dark room would be fine too.
Soory PIO, overpost.
I run my 4 ohm speakers on the 8 ohm tap on my Eico HF-12's as it sounds better, and doesn't seem to hurt one bit.
Beware of possible strange anomalies.
I was testing some small bookshelf speakers with my Sansui and something was just not right (the speakers where 8 Ohm). :sigh:
Suddenly the volume and balance controls where "rough and scratchy" sounding (previously OK). :no:
I hooked up a scope to the output and found ultrasonic oscillations and noise on the output that did NOT appear with other speakers or a dummy 8 Ohm load. :thmbsp:
With my present speakers (floor standing size) there are no problems. :yes:
Maybe a strange crossover\couture network in the small speakers? :scratch2:
Mark T. :music:
