Some of the guys will have a fan blowing across the heat sink when setting the adjustments also you should have it sitting like it would on all four feet. If you don’t already.
The only thing that i can think of to cause this is high frequency oscillations. At low freq's the R is shorted out by the much lower coil R, or the coil is open which is another hard to believe one.but mine likes to burn up one of the resistors that goes across the coil at the output
will have to dig it out to find out . its buried in my caravan right now .What's the serial number on yours Pete?
I noticed when I adjusted the NSA on a sx-3700 I had the set on its side. The heat from the lower sink was engulfing the top heat sink causing a little frustration. They are sensitive.Some of the guys will have a fan blowing across the heat sink when setting the adjustments also you should have it sitting like it would on all four feet. If you don’t already.
That is a possibility. Shield or remove the thermistor. We are assuming it is 10K, we do not know what its characteristics are. slopes NTC, PTCI'm wondering if the drivers are getting hot and the thermistor nearby is causing the circuit to shutdown thermally?
Then he tried to use sub bjts and the design would not bias & oscillated.Went to switch it on today and it took longer than usual to come out of protection. Then I heard a slight crackling noise from inside the amp. Turned it off, and smoke came out from the front right corner of the amp. Damn.
Are you able to make this measurement?My main concern is getting it to run with the same THD figures
me too but my time is limited on this one.. I don't completely understand the purpose of the second adjustment yet so I think I'm just defaulting to trying to get the original results back and if the sim biases correctly and the real one doesn't It'd be nice to know where the difference lies.
