QSilver
But did you recap it due to a problem or did the problems start after recapping.
The drivers may have run hot for a long time but it is possible that they were fine.
As I read your description when smoke came out one channel failed, how did
the second channel fail?
It had a lot of problems and I recapped it while I repaired the other faults. Someone has been in before me and screwed up the power supply board. Incorrect zener diodes and regulator transistors.... The pre-amp was dead because of the regulator board so when I got that working I re-capped it too - there's not many in there and looking at the blown zeners and general condition, I'm pretty sure the drivers weren't good. They were very black and as I said. One on the bad channel was oscillating and breaking down periodically which is what probably knocked out the output transistor. The smoke was caused my a 220 Ohm resistor.
It worked well for a week or so and then started to slowdown coming out of protection. I hadn't been able to use it much prior to that as the pre-amp was dead. Everything was looking very tired.
The second channel didn't fail per se. But once the other channel blew and started to oscillate, so did the other.
Thinking back now, I might've said this already, but I think it was Channel 2 (R) that blew, the one that now has the slight high frequency waveform so although it's "stable" perhaps there is still something not right somewhere.... if there is, it might be the ceramic caps as most of those on testing are towards the edges of the 20% margin and I've heard of ceramics going microphonic also... but maybe I'm making too much of it.
Are you able to make this measurement?
To a point. I have a Radford D.M.S. Series 2.
me too but my time is limited on this one.
I would suggest to add a bleeder R and a 1u/100V poly film across the big ecaps.
I had thought about 2.2uF maybe 10k for a bleeder?
