I agree. I have an original (unmolested) 317 that sounds very much like the 717 that has been fully restored. The 317 is slated for a rebuild somewhere in the next few months. I don't expect the sound to change very much. The 317 runs out of gas at a point, but that point is far louder than I ever listen for more than a few seconds.Thanks a lot!
I've owned and restored/recapped a 217 and a 317 and I find the latter with a considerable increase in everything, sound quality and "punch", the 317 doesn't really looks how it sounds, it sounds like a much more powerful amp
I'm not sure how I missed this post until now. I'm in the process of restoring a 217 as well - having completed a recap and other unreliable components. Leestereo, you've inspired me to use this unit to test out changes before committing them to a more expensive unit.+1
IMO, the AU-217 can be a real sleeper/giant killer. My own unit has been used over the years as a test-bed for various component upgrades and modifications. Here's a picture of the power amplifier stage as it currently exists:
Its glue... the caps aren't leaking... did you measure them?Some leaking caps,
Hello. This is my first post (reply I guess) here. I have an AU-217 that I got for $70 in a pawn shop around 1981 (I think). It has run since then just fine. But last fall it died (power light went off and no sound).
So glad to find this thread.
I have the schematics.
I am going to replace all of the electrolytics and any resistors whose values have drifted. Should I replace the power transistors as well (the 4 large ones)? Is there anything else that I should replace? I am putting together a parts list so that hopefully I can get what I need with one order.
Thanks in advance
Thanks for the tips. I do plan to go over everything when I get time. I need to build a bulb tester (been meaning to anyway). I do have a oscope, signal generator and other goodies.I think your approach of shotgun replacement of capacitors, ect, might make it difficult to determine the cause of the problem with your amp. You should first diagnose the issue, fix it, then consider a restoration.
1) Check the fuse(s) first. If blown, check for shorted output transistors. Search the forums if you don't know how to do this.
2) If outputs are not shorted, you could try bringing it up on a dim bulb tester. If it glows brightly, you have a short to track down. If it dims and the relay clicks proceed to step 3. If not, check for DC offset at the output of the amp stages (search forum for descriptions on how to do this. You're probing where the emitter resistors for the PNP and NPN outputs connect together).
3) Even if the relay clicks, you should check that there is no DC voltage on your speaker terminals before connecting speakers.
4) Try running a signal through the amp.
Take this a step at a time and feel free to report back and ask more questions.
@kgwrocks I think with your background fixing this amp will be pretty easy. Everything in this amp is easily accessible and the component count is low. Also, in my experience, these amps don't get abused like some of the higher end units, and generally don't suffer from massive failures. Hopefully yours follows that trend. We'll look for your new post when you get started.I was not going to replace components willy nilly. But since it is over 40 years old, replacing the electrolytics is sort of a given. I'm pretty sure that it has lasted so long it that I leave it on all of the time (not sure if that is a good thing, but I had heard that leaving SS amps on helps the components last longer). And it ran fine up to the end of last year.
I've been super busy, so I have not had time to dig into it yet.
But initially, I did open it up and take a look. Fuses are good and I recall that the relay still clicked.
Also note that I have build Hifi tube gear (my main system for the last 24 years), tube guitar amplifiers and SS guitar pedals and power supplies. I'm a little intimidated about working on the AU-217, but am confident I can do it.
And great idea to start a new thread. I will do that.
thanks - Kevin
For the AU-217 and AU-217II - the original 6800uF 50V PSU Electrolytics are 4-pin snap-ins - 35mm diameter - 60mm height - lead spacing of 22.5mm
Current possible replacement's are
NOS Panasonic TH-A 8200uF 80V - drop-in replacements currently in stock at Mouser Electronics
or Nichicon UKW 6800uF 50V also currently in stock at Mouser Electronics - these are leaded which can be bent to the correct required lead spacing
I was thinking about picking up one of these amps. What are the odds I won't have to do any of this restoration? I just don't want to get in over my head.
Very slim, even if the seller says it's been 'serviced' - this means nothing in many cases, but rarely you can find one that has been 'restored' - rather than only 'recapped' two different things in my book. - good luck with your search.What are the odds I won't have to do any of this restoration?
