You could listen to it just to get an idea if it works at all, and an experienced ear could say if it sounds 'tired' and in need of reconditioning. You are unlikely to find out much by measuring things with a 'meter' I'll assume 'multimeter' here, i.e. Volt/Ohm/Ammeter.is it obvious that it would need to be restored by just listening to it or do you need to use a meter to test things out?
With the cover off you could very likely see if the infamous 'Sansui Glue' is still present - indicating that it hasn't been restored - not 'properly restored' anyway. I think I can safely state that any home audio of the same age as an AU-217 will need some work, i.e. cosmetic, and switch contacts & controls cleaning for example, at the very least.
The AU-217 is a very nice amplifier, but will only sound it's best after 'proper reconditioning'
