Sansui G-22000 Restoration/Upgrade Thread
First, nice work there. Set up looks the same as mine, so definitely safe to say the manual either has the polarity wrong, the capacitor ID numbers reversed or I'm reading it wrong. Either way, time to get it done. Appreciate everyone's time and comments. I may have more crazy questions as I work through this thing. It will be a long process though as I was lazy and ordered a cap kit off ebay. Never seem to get one that's been properly vetted, so constantly finding they missed stuff.
Thank you! There were production changes I bet so maybe why the cap kit wasn't quite right.
Can't check voltages now as I had to pull the thing half apart just to reveal the wiring on those caps. My plan is to wire the new caps to match the current config of the unit and not the schematic. However, I was hoping someone who's been through the process on the 22000 would chime in and confirm they noticed the same discrepancy- I'd feel better.
I've worked on a number of these amps, there is nothing odd about them, it's very straight forward and typical of a complementary output stage. You don't need the wiring diagram to confuse you.
You will have a +'ve supply rail and a -'ve supply rail.
You will see the -'ve rail connects to the 2SA (PNP) output transistors, and the +'ve rail connects to the 2SC (NPN) output transistors.
That will tell you what you need to know about the capacitors polarity. Just be aware that the POSITIVE terminal of the cap for the -'ve supply rail will go to ground.
You can see this in the pics of the last post, but ALWAYS verify you have it right otherwise it is a big messy and smelly explosion!!
Let us know how you get on...
Left channel filter caps done. L/R power supplies and driver amp PSBs recapped. All transistors with a heat sink got new compound. I bought this thing used around 2003, but this is the first time I've really spent any time inside. Looks completely untouched and in pretty good shape. No heat stress on any of the PCBs. Time to fire it up on the DB tester and if there no issues, I'll press with checking the adjustments before moving on to the preamp/tuner section- not looking forward to that.
Dont forget to replace the few fusible resistors there are in some G22000, there are two on each driver board, and there are a couple in the regulated supplies.
Some have them, some don't, but worth checking, mine had them and of course they had all drifted way off spec.
Thanks for the heads-up! Now that you mention that it seems I recall reading that somewhere. How would i recognize those or how are the ID'd in the manual? They're not jumping out at me. Don't know that I've ever seen a fusible resistor .
They are often low resistance values (single or double digit ohms with no multiplier) and usually the bodies are kind of a chalky greyish color, which sets them apart from the brown and tan carbon resistors and the blue metal film types. The schematic and parts list will be typically list them as "fusible resistors".
