boreas
"If it sounds good, it IS good." E.K.E.
Setting the TF was a bit of a chore, seems that I had to have the table running to do that (with very little space between the arm rest and the platter).
Next time unplug the turntable or slip the belt off the capstan.
The anti-skate has me puzzled. It's the type that's made up of two small shafts that pivot. There are no rings or gradations on the shaft with which to measure
The weight disk is secured with a small set screw as I recall. I think setting it in the middle is appropriate for 2g of VTF. Toward the ens of the shaft for more, toward the pivot for less.
(not to mention that the small weight on the end of the shaft doesn't seem to move at all anyway).
There's often a set screw for that as well but I don't see it. Maybe it's preset at the factory. It's not all that important, really.
I'm curious as to how I should set the cartridge overhang. I know that a lot of Japanese s-arms seem to want 49mm.
The 49mm shortcut is Pioneer. That's a C.E.C. table and I think they use 50mm. I also believe that you can set the overhang on that table the old fashioned way by lining the stylus tip up with the inner edge of the trim ring on the mat with the arm over the spindle.
The OM & SM for the TP 625 at VinylEngine will help you with setup. It's very similar.
John
