Not that I’ll notice it but original wow/flutter spec was 0.04%. Original SP-10 (MK 1) published a spec of 0.03%… Looks like they were intended to compete. All I can say is, glad I picked this 2251 up..
P.S. - I’m really liking the cork shoes on this..![]()
Flavio, I’m really liking that plinth you have… Did your plinth guy charge a whole lot for it? Curious…![]()
I just made a request of the online moderator - so, maybe..![]()
Just changed it. While I was apparently online when you sent it, I didn't get to it til sometime later.
Well - going for a drive through Los Angeles this morning to pick up my second 2251..
No fun, but it won’t have to be poorly packed (?) and suffer shipping damage….
This one was relatively cheap but not as clean as the first 2251 I brought home. I’ll probably post a few pictures later today, after evaluating it. If the original plinth veneer is a bit too scruffy or the dust cover too scratched, this one may be good for a dual arm table in a bigger, new plinth..![]()
Helpful info for those rebuilding 2251. Capacitors. All electrolytic:
Cans - 4uf 250v, 16uf 50v.
Others - 10uf 350v, 470uf 25v, 470uf 16v, 47uf 16v, 33uf 16v (x3), 4.7uf 25v (x2), 4.7uf 10v, 1uf 50v, and 1.5uf 16v.
@loomis - not sure if you’ve been around recently but in case you do stop in…
Did you ever get around to recapping one of these tables..?
How'd did the drive go?![]()
When I got there the seller switched it on and - no strobe lit and a light scraping sound.. Not a good sign. Switches are sticky, too.
I pulled the platter to see both brake magnets loose and way out of their positions - BUT the motor runs. It wasn’t crazy expensive so I took it as a challenging project.. Getting home, I put the magnets in their places and switched on again. Now I have a strobe! The speeds do adjust up, as well. I added a couple drops light oil and let it run for an hour. Nice and quiet. Biggest concern seems to be low torque (?) so I’ll need to do some measuring. This may need a recap…
Plinth may clean up OK and dust cover isn’t too horrible.. Armboard for the Sony arm looks perfect.
This one’s going to need some work but since I grumbled quite a bit - the seller threw in a (possibly unused) NAD/Rega RB250 tonearm.. I’ll post some pictures of this one tomorrow..
Score!!
That the magnets are off give you an opportunity of confirming the magnet height is OK, following the procedure on the service manual. The target is to reach a certain AC voltage on the motor coils when the turntable is at 33RPM.
As for the strobe, if it fails again there is a replacement:
Some clever guy used a blue led with a resistor.
Source:
http://soundaries.com/2014/01/tts-2500-part-i.html/
However the resistor value is not disclosed. Now, you could wire a 10K or 50K potentiometer and carefully turn it until the led turns on, then you would have the correct resistor value.
Anyway, I should have bought the nice one that was in Temecula. Though more expensive, it seems a much better deal.![]()
Low torque is prolly motor related. Not capacitor. There maybe more alignment needed.
I bought a pretty worn out 2250, just for parts. Board, motor, something I can work and learn on, if need be. I've only tried it to see if it works. Never played it.
Yeah, be interested in those photos.![]()
We may need a few of those parts…![]()
I always look for donors. Especially, in these hard to find units. Specific parts are becoming unobtanium.
A good electrical engineer could design a completely new control unit for those turntables. It isn't THAT difficult.
Perhaps some japanese guy has already done it!
This one I just bought was the $200 donor - but I think it’ll fix up OK and make a nice table again. Still early here - pics later..Or you could fish the parts off a $200 donor. Hard to find those donors anymore.
