Looks like the arm may need a new insert. Which may have to be DIY'ed?It looks like a droop to me. Is that the one in Temecula, by chance?
Looks decent - probably a good buy but that arm looks funky.. Arm cuing lift pad is facing wrong way too, I think.
@sberger - you’re right. Looking at a few of the similar Sony arms from that period and even shown in their manual illustrations, that’s a designed-in droop and pitch to to the right (looking from front). Probably just fine.
I have a spare 2250 with has this arm --- I have never used that table. It sits in storage, whenever I need a board or motor.
What are you referring to as the "insert"?
Whatever that part of the arm is inserted into. Black plastic sleeve at pivot point. But maybe, no work needs to be done. Seems that the counterweight is on a slight bend from the pivot point.
That's what I was asking about above. It's been indicated elsewhere that because the the counterweight is offset horizontally, it's supposed to have the droop shown. When looking at other pictures online of the arm, that seems to be the case.
Seems you are okay!
Maybe, it's like that to have complete range of motion, when the cover is down?
Maybe. All I know is what I've seen online. Just going to bite the bullet and keep my fingers crossed. I've provided detailed instructions on packing, and at least it's not being shipped cross country, so hopefully this will all end well.
So silly really, given the 7 working tables I already own, plus the 2251.
But you guys understand that.
Take a look at the Sony PUA-237 / PUA-286 tonearm manuals on Vinylengine. Here, even the brochure shows that “droop”..
Thanks guys! Appreciate your help and good wishes!
Hey guys, the title of this thread has in it “2251/2250” - just like that, all shoved together. Think we could get a moderator to add a couple spaces around the slash, so we get both numbers, instead of that one?
I mean so that reads “2251 / 2250” or “2251 and 2250”.
That way (if search gets fixed), people will see an actual # that they search for.
Can a moderator fix that?
Try PST'ing whomever is currently online. I've seen edits to titles before.![]()
