dnewma04
The Healer
I am starting to wonder if it would be good to make cabinets out of layers?
Fiberglass insulation lining, then styrofoam sheets, next a layer of balsa, finally mdf and plywood. Any thoughts?![]()
Again, the fiberglass insulation is to reduce standing waves, it has no bearing on the resonance of an enclosure.
Changes in material impedance can make for good soundproofing devices, but we can keep this simpler for speaker building. Adding mass lowers resonant frequency. Adding stiffness increases the resonant frequency. Adding both mass and stiffness, depending on the combo, can either lower or increase resonant frequency but should decrease the amplitude of the resonance, in either case.
