SPEC 2 Reed Relay
Are you talking about the DPDT relay that sits next to the bias interrupt relay? The US Relays DPDT 24V open-line relay, Digikey part number Z649-ND, has the correct pinout, but I think it is too long (1" from the leads on one end to the leads on the other).
All this relay does is change the current limiting resistors when the amp is set to either 4 ohm or 8 ohm,
Yes, that's the one.
The unit currently has a real mess with a non-stock relay with wires running everywhere. I just wanted to clean it up.
Thanks,
