Stylus choice for Yamaha PF-1000?
Shonver
Audiophiliac
I have a choice of Technics EPC-310C and an Ortofon Rondo Blue. Which is likely to give better performance with a Yamaha PF-1000 (similar to PF-800) turntable?
I can´t find anything about the Technics, but judging from the model#, I think it´s a P-mount cartridge, which won't fit the Yamaha.
I could be wrong though.
I made a mistake with the Technics model number. It is EPS-310MC, alternatively called EPC-310MC, I believe. I do have an adaptor that allows the T4P cart to be fitted to a 1/2-inch mounting.
Well, I tried them both, and the Technics cart really sounds good. It sounds much better than the Ortofon, which seems a bit heavy for the arm.
Heaven... I'm in heaven...
I borrow the thread a bit with another question on the PF1000.
Does anybody know what the weight of the tonearm is?
Would it work together with a Denon DL103?
Best regards
The PF-1000 is supposed to handle carts between 2 and 11g, so the 8,5g of the DL103 is close to middle of the road.
Ok. But how about the compliance. Thats what i´m really worried about. The DL103 got a very low compliance especially in the specifications (its measured at an unsual frequency.
Best regards/Carl
If the Technics is in good shape it should run circles around the Ortofon. It's a HOMC so it should work fine with a MM phonostage. You can register (free) at vinylengine and read more on it...
http://www.vinylengine.com/library/technics/eps-310mc.shtml
I've got a PF-800 with a Shure V15 lV.......this works quite well,but a Denon DL-160 is standing in the wings.
Best regards/Carl
The PF-1000 came org. with the Yamaha MC-705 witch has 6 x 10-6 cm/Dyne and 4.3g, so if you compair this to the 5 x 10-6 cm/Dyne and 8,5g of the DL103. You will get close to the same result acording to vinylengine.com, I will say the DL103 wil do real fine on the PF-1000.
Also see the note on vinylengine: Denon publishes their dynamic compliance specifications relative to 100Hz . The actual compliance at 10Hz will be higher
http://www.vinylengine.com/cartridg...s.php?m=Denon+DL103&cm=8.5&dc=5&search=search
http://www.vinylengine.com/cartridg...php?m=Yamaha+MC-705&cm=4.3&dc=6&search=search
YAMAHA MC-7 MOVING COIL CARTRIDGE. SOME TECHNICAL DATA: V-H matrix moving coil type
Diamond "Vital" eliptical stylus (8 x 20 microns)
Output voltage: 0.3 mV
Channel separation: 28 dB or more
Electrical impedance: 30 ohms
Frequency response: 10-60000 Hz.
Tracking force: 1.5 g.
