This is going to sound dumb but make sure the cable with the white inner wire actually goes where you think it does. I made that assumption on my ROK, turns out the cable with the white core went to the red plug, and the one with the red core went to the white plug. factory-assembled ends that can't be swapped, so it must have just been made stupidly.
I checked the wires with multimeter and they are correct. Thanks!
Should work.....I'm thinking I see two ground wires going up into the tonearm and that is different from what I see on my 160. Not sure what to make of it, but give it a try and see how it sounds. If you have no hum then you would appear to be good to go.....
BE SURE TO START OFF WITH YOUR VOLUME TURNED ALL THE WAY DOWN AN THEN INCREASE IT SLOWLY SO YOU DON'T DO ANY HARM TO YOUR SPEAKERS......
Ok, the "boom boom" sound is gone, but there is a
hum now when the speakers and TT is on, but no music is played. I don't really hear it while playing music (except for low volume passages on records. Moreover I can hear static if I touch the metal plater.
CEC and Thorens comparison
Now the whole update. I've been able to A/B test The Thorens with Grado Green Prestige 1 and CEC BD-2000 with AT-VM95E. Mainly using Bill Withers - Just As I Am (I know this record well so it was a good choice for me.)
I would say, I prefer the CEC sound, it's smoother, a bit warmer and richer, maybe more spacious (not sure about that one). The vocals are more forward sounding and clearer.
Thorens sounds harsh by comparison, I can hear it being more precise but at the same time vocals are bit distorted and mudded, definitely not as smooth sounding.
The mid-low end on Thorens is definitely louder and tighter, wich is nice but makes for harsher sounding playback. It makes electronic music more dynamic but it's not really suited for soul and jazz for me.
My stupidity
The distortion on left channel which I mentioned in previous posts was not an issue of TT. Maybe some distortion, as it sounds better now after doing the wires.
CEC has the same distortion on left channel, I might have damaged the record I was testing this on. The distortion of Thorens are clearly heard and harsh, CEC on the other hand I can still hear them, but they are much softer sounding.
Overall thoughts
Next I'll try to get rid of the hum, if someone has any idea how to do so.
I want to try different carts I own to see how they compare on TD160 to get a better idea what are the characteristics of this TT.
I would love to get a bit more laid back sound, smoother sound. At the same time I'm disappointed by the lack of clarity in sound. I wonder if the cart is maybe worn?
It's a Grado Green 1, and I have no idea how long was it used before.
EDIT:
I switched the cart for AT 3600L (changing a cart on this tonearm is a nightmare).
Vocals are now clear (not distorted). Overall it sounds better? Maybe not better, but it sounds correct. Sounds are just clear. VERY FLAT but at least I can enjoy it.
Grado was distorting vocals, producing very harsh high frequencies and very strong *low frequencies (*that might be mine speakers, phonostage, cart combo).
The hum is still there, so there is still a grounding issue. At least I know my Grado cart is either broken or just worn.
Update on Grado
It looks like the contacts on a needle and cart are corroded. Is there a chance I can clean it? Or cleaning near coils won't be possible?
