Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Sort of a sub for the HF. . If your speakers need it it can be beneficial. I added HF drivers into my cabs and it really brought out the tinkle in certain music much the same as a sub will in certain music. But if it isn't there in the music then you won't hear it.
Maybe one way to tell if your current speakers are lacking in certain frequencies is to get a calibrated mic and REW software and test it.
I really like the airiness that the stock supertweeters on my Dahlquist DQ-10 bring to the party. This is true even though like most men my hearing is declining at the upper range. It is interesting that the recommendation is to simply hook them up in parallel. With a 5 ohm rating, I wonder what that does to the impedance of the speaker system?
The impedance would worry me though, especially with a tube amp. I hadn't thought about it but I don't think there is any way around ending up with much lower impedance.
Or would the lower impedance only apply at higher frequencies where the power is lower and not be as big of a deal?
I tried a cheap ribbon tweeter on all of my setups with varying capacitors, it was awesome. Then I tried to make it a dipole, r.I.p. Mr tweeter. Gordon W. has a good post somewhere (hatu) about the piezo working well if implemented right.
Eh ... I plug mine in when I want to annoy the dog ... ;-}
I do have a pair of the original Radio Shack Super Tweeters that are nice. Metal horns and built in crossovers to get around any impedance issues. T
hey collected dust for ages, but I did eventually resurrect one for the Eico amp used on my center channel - added some top to a Bose video speaker that needed a bit more punch.
Speakers from the 60's had natural roll offs to simulate the live. concert experience that was un amplified and to mask the distortions of recordings, LP's , and tape hiss. By the 80's with the popularity of electronic instruments full range performance was required and great strides were made in tweeter development. I use super tweeters as my original tweeters start falling off at 12 kHz, Which was very common at the time. Todays speakers of sufficient quality can be 2 way or three way and easily extend beyond 18,000 HZ. with very low distortion that couldn't be produced back in the early 70's, until Macs line arrays came along. Its just been the last 10 years or so that JBL could build a big driver with less than 2 % distortion and woofers with less than 5% distortion. There have been a lot of improvements since the turn of the century, so why not take advantage of it. I know its the cost. I wish you luck and the patience to do a lot of research. Knowing your dynamic range requirements is the first parameter.
My main speakers in the media rm incorporate one of the most famous. Now some may argue that this is actually a tweeter, and they would be right, but as it's response goes out to 45khz I would say it's both, it is one "super" tweeter.
I love the shimmer of cymbals and these give me that and more. They're B&G Neo 3 planars with open backs which allow front and rear radiation. Incredibly smooth and detailed when so many I find are too hot and edgy. Used a 1.5uF cap on it's + terminal and they're parasitically driven from the speaker terminals.
