I always used 8cu in the VE calculator for the DL-103 and that seemed in the ballpark based upon the tonearms I've used.
They do as it can be measured which was my point a number of posts ago.I've spent a LOT of time researching everything I could about the Denon DL-103 series of cartridges and the one thing I hear over and over is it didn't really start to shine until it was paired with a heavy mass tonearm. Sure, it will work on a mid mass tonearm but you give up a lot. I don't think anyone really knows what the actual compliance is but it doesn't really matter, just run it on an arm with an effective mass starting around 20 grams or so, go heavier from there.
Yep, that's a number I've used as well. Seems to work.
BillWojo
All of the above are just fine if you rely on measurements and base your recommendations on things like "opinions", "should give", "probably", "seems to be". But you're not going to get the most out of that cartridge by sticking to those limitations.
Does anyone TRULY know what the actual compliance of the DL-103 cartridge is? It looks like the measurement monkeys think they know, but when you look for actual figures they are all over the place! Multiply the Denon-specified of 5@100Hz by what to get a figure that can then be used with the compliance calculators that are found on various websites on the 'net? Multiply by anywhere between 1.5 and 2.0? That's certainly going to give you an exact figure to work with, won't it?
Do you even have a 103 equipped 'table or is what you posted above based on conjecture?
Measurements are fine, but the ultimate is to listen for yourself and then make the determination. I can tell you this - you haven't really heard a DL-103 (or 103R) until you've run it at 25g to 30g (or possibly more) total effective mass.
OK, the Denon DL-103 is a rather low compliance cartridge. It apparently requires a rather higher effective mass tonearm. What tonearms would compatible with this cartridge?
It's a simple matter of (rotational) inertia, which is what 'effective mass' is. Inertia (I) is affected by the mass (m), and the distance (radius - 'r') of the mass from the pivot. The relationship is expressed as I=mr². You can see a linear effect of mass - but exponential effect of distance. This means that if you increase the mass two times, inertia is increased by two times (linear relationship), but if you increase the distance by two times, inertia is increased by four times (exponential relationship).Also, would you please be so kind to answer the question: how does the position of the counterweight influence these results - would it matter, if I tried to use the third, most heavy counterweight, which will sit nearer to the pivot?
I had tried out that very DL103R in a Linn Ittok and a Linn Ekos and resonances were not as pronounced and bold - is there any explanation for that excessive behavior with the SME?Cartridge behavior at the resonance frequency is going to be uncontrolled. Whether it's horizontal and/or vertical motion.
SME's, other than the very old series II 3012's and first version 3009 (stainless steel armtube) are NOT a good match for the DL103 and DL103R. This cart begins to shine at 19g eff. mass, and anything bellow that is not advisable. Knife edge bearings have their own quirks, even when assuming the knife edge is intact. SME had used nylon bearings on some variants of the 3009, so there's too many variables in this equation, with eff. mass being the most important.is there any explanation for that excessive behavior with the SME?
Interesting advice worth trying, thanks! Just to be sure I understand you properly: do you mean 500.000 CST oder 500 CST (you used a "K"), since 500.000 to my understanding has a consistency, that does hardly flow at all ("gel"-like), while 500 might be something in between vegetable oil and motor oil (aka "super-viscous").couple drops of super-viscous 500KCst silicon oil
thank you this answer clearly made my day!Double peanut butter viscous 500,000
I would not do this. Oil should not be added to any tonearm that uses a dry knife edge. All you are going to do is inhibit some of its movement and attract dust.You can try to add a couple drops of super-viscous 500KCst silicon oil in the wedge, on both sides of the knife edge bearings for damping, and expect some improvement.
