Depends on your "use case". My only experience is with 19V laptop bricks. They work well. The higher the voltage the more watts you will get. Most folks don't need a lot of wattage, lots of folks are quite happy with 12V supplies.
Anecdotal evidence... was playing with my dual mono PBTL amp (modified red boards) tonight using a 19V brick (10A) that powers both boards. Lots of questions around here thinking a laptop brick isn't good enough. Also posts about why anyone would ever want to run the 3116 in PBTL mode since the TPA is only rated for 2-3 ohm speakers in that mode. I'm currently testing a couple of different speaker pairs (low efficiency 86-87 dB each) to see what I like best, each pair is 6 ohms, and the TPA with the 19V supply will drive either set into distortion and not have any power issues.
Then I said what the heck, let's put them in parallel and dial the volume up. Good grief, the 3116s deliver when pushed to the limit. Heat sink hardly warm too... didn't run for a long duration but I will
With higher efficiency speakers that what I have I can't imagine power supplies are even an issue.
