And yes you are correct it would be 1/4 the DCR for a non center taped tranny being used as a voltage doubler that achieves the same voltage as a center tap design. From end winding-center tap-to end winding...
OH, I am suggesting that the doubler transformer might have ~1/4th the DCR of a typical non-CT transformer used with a bridge rectifier, and ~1/16th the DCR for an equivalent full-wave CT transformer. This is just in terms of coil DCR for approximately equal dissipation, not apparent resistive contribution to supply impedance, not accounting for core differences, not accounting for the primary coil resistance, and I'm certainly not factoring in cost :thmbsp:
Imagine a hypothetical transformer with 4x 16 ohm coils at 50V each. In one case, you can form a series total 64 ohm 200V FWCT coil, in another a 16 ohm 100V series-parallel combination for a bridge-rectified circuit, and another a 4 ohm 50V paralleled coil for a doubler circuit. So this is a hypothetical transformer that can do it all.
With large enough input capacitors, the doubler will perform very similarly to the bridge rectified circuit - both in terms of time constant and overall impedance (within a diode's drop of each other), but the FWCT will exhibit approximately twice the resistive supply impedance contributed by the PT than in the more efficient bridged and doubled supplies. The halved DCR contribution is offset by a factor of 4 increase in DCR -- likewise, the doubler's quadrupled DCR contribution is offset by a factor of 4 reduction in DCR compared to the bridge supply.
Since the doubler requires better / larger caps, and almost certainly a custom power transformer, I view it (today) as a "luxury" item when it is designed to equal other supplies - it is (IMHO) a safer supply in terms of voltages involved, and should be more reliable if designed for equal output.
Attached are sim results for the bridge / FWCT / and doubler supplies using the 4-coil hypothetical ideal transformer. Initial current draw is 100mA, final current draw is 150mA. The FWCT in PSUD requires that I specify half of the coil as input, hence the 100V-32R vs. 200V-64R. I am also cheating in that I'm not accounting for primary resistance. And, pardon if these look squirrely - I run a Windoze emulator on my Mac
Please note, however, that if you cut the DCR of the FWCT transformer in two, it becomes equivalent to the bridge-rectified supply. But, if you are holding an Antek power transformer wondering what to do with the two coils in your monstermonoblock, my advice would be to parallel them and use a bridge-rectifier instead of a series FWCT.
