A 100 Ohm's of resistance in a Supply path
Thank You seta1,
There's a lot in this opinion so I'm going to make some comments piece by piece here.
First off I'd like to say to all is, seta1 is certainly entitled to his opinion and he certainly has a lot of experience but his experience does not parallel mine at all
Hi,
You are correct in that the power supply will stiffen up without that resistor in there. But this is only going to have a real big impact in amps that are biased below 3/4 of maximum output tube plate dissipation.
Thats a first time I have heard that! The plates on the EL84 that I heard might of been running at 85% of its dissipation.
With my own amps I can use two tubes the 811-10 and the 572-10 both tubes run in Class A2.
The 811-10 runs at about 50 watts dissipation, it has a 65 watt plate dissipation.
The 572-10 runs about 60 watts dissipation and has a 125 watt plate dissipation.
The 572 sounds more extended in the frequency extremes but only slightly.
The 811 is smoother I think cause it has a metal plate vs a graphite for the 572.
The differences in dynamics are more likely because of current use IMO and the 572 has a 20% lower plate resistance as well this gives more transconductance for the same gain which is nearly identical.
Also
Dynamic Conductance is Gm X Load, Gm is directly proportional to current. Its current that generates dynamic impact. Its a very important concept for generating dynamics.
Its not all of the story but its a good chunk.
The other part of the story is loading.
Its what makes good current sources like the C4S that I use from bottle head in the front of my amps really work!
Here
http://www.bottlehead.com/et/parts/parts.htm
Scroll about 2/3 down and you'll see the kit.
The C4S is also great for phono circuits not only generating dynamics but tremendously reducing noise as well! It does so by creating up to a 5 mega ohm load! The noise ends up over the current source! instead of the tube!
I learned a lot from this book and I highly recommend it as it will give far greater information on operating specs of tubes than most tube manual's it only covers signal tubes but the same theory applies to power tubes
Here's one source for it.
http://www.john-a-harper.com/valvebooks/valve_ref.htm
I tried it in amps I build and no effect. But my amps are biased such that at idle, the plate dissipation is at maximum (25 watts for each EL34 in the push pull designs).
If I hear it in an EL84 I believe I will hear in others I have no idea what the rest of your system is but it could be an influence!, Its the next item that's severely limiting IMO.
I actually have two RC filter networks before the B+ goes to the output transformer. I run about 100uf off the 5U4 with a 20 ohm resistor between the 5U4, then a 40 ohm and another 100uf and finally another 40 ohms with another 100uf capacitor before the B+ goes to the output transformer.
"A 100 ohms!"
The Pilot I redesigned has just as much capacitance being used with a GZ37 a directly heated rectifier as well.
Another factor here maybe the dynamic conductance being higher with EL84s than EL34's like 10-15 for an EL34 PP and 20-25 for an EL84 I didn't think of this until just now! and the gain in the output stage being 23 vs an EL34 maybe 8-10!
All I can tell you is that, when I bypassed that 100 ohm on my friend Don's amp whose ears I trust far more than most peoples he turned his head slowly and looked me in the eyes and said.
"If it gets any better I'm going to creme my pant's"
This was on his ProAc Response II's a pair of $3000 mini monitors that were fast quick and had great bass response as well! Later he got a pair of Dunlevy 4's.
It wasn't subtle folks With the PP EL84 that I worked with! Not to his ears nor mine.
This is a guy that was formally a musician and typically goes out and listens to live Jazz, Big Band and Classical concerts 3-4 nights a week and I can assure you he doesn't exaggerate sound nor does he miss a beat.
Funny, often when I'm out with him he'll say "did you hear that!" then he'll explain with a smile how someone was out of sync in one way or another.
I feel very fortunate that I have him as a reference pair of ears. When I was designing phono stages it took me about 3 yrs before he gave the nod before I beat a good SS MC Phono Stage he was using. I can't tell you how many times I put my head down with him saying
You'd think a 20 watt Pilot would crap out on a pair of Dunlevy 4's! Not this one!
Nothing was flabby, slow or undefined especially in the bass! Dunlevy 4's have some of the best bass pitch definition I have ever heard.
I remember Don telling me he was a little concern about the Pilot driving the Dunlevy's as the minimum recommended power people were talking about using was no less than 100/watts channel!
His concern settled after one LP cut! From his Linn, Aro, and Benz MC
I remember him saying jokingly to me! "I thought tube amps weren't suppose to have bass?"
I said thats what some people say!
Talk about tuneful!
I honestly believe it was all about energy transfer! If not the Dunlevy's would of told us! IMO
On SET amps using two 2A3's in SET parallel, I have a 5U4 running into a 20 ohm resistor and then a 200 uf capacitor,t hen a 5 hy choke followed by a 300 uf capacitor, then a 40 ohm resistor followed by 400uf capacitor. Ripple is around 10 Mv at the point where the output transformer connects to the power supply.
Wow, I couldn't live that!
The contrast between your amp and by mono's is like John Kennedy's PT boat vs the Cruiser that ran his boat over and my amps aren't the PT boat here! Now try to imagine the Cruiser only with PT boat speed.
If the output and driver stages are running on caps that big. Thats not a very fast time constant. I run on two 40 uf AEONs for the output stage and a single 40uf AEON for the driver stage both of which are highly isolated from the rest of the supply thats wher my speed comes from!
The foundation of the amplifier is the energy reserves of the bulk electrolytics that I use!
Now here's the key! The PP cap signature is totally intact using diodes to isolate from the rest of the supply. Even the signature of the diodes is not apparent at all.
I'll explain more when I go over my phono supply.
I wonder what the DCR was on the choke?
We could be easily talking in excess of 100 ohms here in the supply path total! Bad news IMO.
IMO its better to use small L's with 5 or 6 ohms like a 500 mH choke and do an LCLCLC But I would prefer CLCLC so I could keep the power transformers windings to a minimum DCR as you need a higher AC secondary to do an LC which of course has more windings for a higher DCR cause your lucky to get 85% of the secondaries AC voltage as DC vs 120-130% with capacitor input from a tube rectifier and of course this can change with various rectifiers.
And if I were using a 5U4 perhaps use a resistor for limiting in a CLCLC and use a timed relay to short the resistor out that way arc over would be prevented in 5U4.
I did an extensive A/B test of my amps against an Audio Aero Capitole and both myself and the owner of the Capitole found that the performance of my amps held it's own against the Capitole in all areas but brute power (The Capitole is a push pull parallel 'simulclass design' delivering a rock solid 50 watts from a pair of EL34's paralleled with a pair of 6550's).
A friend in my local club owned one of Audio Aero's CDP's very,very nice IMO.
Their CDP's maybe great but that doesn't automatically mean their amps are in the same class!
I can't tell you how many High End names I was disappointed in when there was high expectation. But thats true for anyone!
I loved it when a dealer told me if you like a manufactures amps you'll love their phono stages! Not necessarily!
But you know I wasn't there and I have now idea what their topology is.
But it seems to me it must be similar to your own! if they held neck and neck.
I'd almost bet its a classical designed supply.
One amp line that isn't designed in a classical approach that I have heard is Art Audio. Very fine indeed!
So, a lot has to do with how the amp is biased and the type of dynamic load it presents to the power supply as to whether or not you will see an improvement if you bypass those power supply resistors in the RC filter networks.
I certainly hear it in my SET amps people are often a little amazed at 10 watts. As my bother was being in construction after I told him it was the neighbor calling to tell me her pictures were moving on here walls separated by two garages between here living room and mine I was just play some Jazz I said!
I have been asked "how can those things do that?" Simply, by design! I have said.
In my amps, it makes no difference.
As I said in mine it does!
I don't know what to tell you, I don't know what speakers or source components you use and we have no schematics not much to go by.
In class AB2 or even some AB1 designs, it could have quite an impact on power supply sag and the overall dynamics of the amp.
By having a fast supply and supply path along with very good parts quality I have found in my experience everything else usually falls into place. Providing the associated parts are voiced for the system and of course the rest of the system is up to the same standard.
Sag, 200 joules 1920uf's/ mono block, hardly!
If you really want a solid power supply, try using a solid state rectifier with a choke input filter network.
Though I have heard a few good sounding amps with SS rectifiers, I use them if I feel the need but in general I prefer tubes for harmonic structure.
Now whats interesting is how Art Audio uses SS rectifiers then puts a tube rectifier after it! All in the name of sound! And very good I might add.
Thanks again for your input seta1!
Cheers SET12
