Me to stanbp64, I know what I like and I have that at this point in my 300B's.Lot of good info here from everyone..... just wish i understood at least half of it. Does open up alot of areas to experiment though. Keep it coming:yes:
stan
Tonight I listened to some CD's in the workshop through my Sansui 1000A. I use it several times a week. By all estimations of this discussion that amp has a poor power supply, but boy does it sound smooth. Because of that I'll not touch that power supply until I have to!
Makes me wonder how Kegger's brew sounds!![]()
I have to agree. My Puresonic Quadramatic Model 112 pre uses Compactrons. All triple triode. The Puresonic Quadramatic uses 2 Mullard 5AR4 in parallel for rectification. 4 12ax7's in parallel acting as one huge triode. It was made to compete heads up with Marantz 8b. My tech and his brother have close to 100 yrs experience between them. His Holy Grail is the Marantz 8b, he finally admitted, that he thinks the Puresonic has an unmatched "certain presence" and he likes it better. It's stone stock, with 40 cans replacing stock 60 cans. 181 damping factor! Superb bass. Want to replace some of the 1965 caps..kinda expensive because twice as many as normal. There ain't no way in hell I'll ever let go of this 'dynamic dou'My thinking is that vacuum tube technology got cut off by transistors just when it was really starting to take off. They were just starting to do some cool stuff with compactrons, like add caps and resistors to the inside stuff. The other thing is, that 90% of all commercial (and most home brew) amps are one of three or four basic designs. This is part of what makes tubes so much fun to experiment with to this day. Thinking outside the box is very easy to do, and sometimes gives surprisingly positive results.:yes:
I have to get on Kegger every once and a while for scrapping out those 1000A's. Man I wish he wouldn't do that! (just kidding Kegger!)
All I can tell you is a 5v change in a EL84 or 6V6 can and at times has had a giant difference in sound. (just did it a week ago)
(so for me the clipping of that resistor does not make the pilot amp a good example) (these tubes like increased voltage a lot)
(now it's within reason the voltage increase, more noticeable at the low end and less at the high end of the scale as well here)
Even with the voltage changed, the energy of the supply for both 100uf caps would be a total of 9.3 joules @ 300VDC separated (4.5 and 4.8 Joules) vs 9.6 joules @ 310VDC combined.Variables would have to be the same on each supply, same capacitance, same voltage, same power tranny, same rectifier and the same stages of filtering, unfortunately you can't get that same voltage with the same power tranny with and without that resistor in there.
So as I said, to many other variables to just say it was the less resistance that made that huge impact there.(the power supply voltage went up as a whole, including the voltage to the driver tubes, which would have an impact here to)
Again, I'm not saying what your doing isn't working for you, but the Pilot example just doesn't cut it for me.
But the as the Tech pointed out, the transformer used as doubler has half of the winding resistance as a center tap!:scratch2: Something I didn't think of!
Actually, it's more like 1/4th, since the transformer will be designed for equal power dissipation. In practice, the doubler works much like the bridge-rectified (or conventional full-wave) supply, except with a safer secondary voltage and series caps on the input. In the 400+ volt range, there are many advantages, and it should be a more-reliable solution.
Congrats Dan on starting and maintaining a great thread!SET you need to get over here so we can go over some of this stuff. If I'm casually listening to music while working on a different project the Sansui is the ticket. It is sweet mellow and never edgy. On the other hand sitting down in the living room and listening to the 300B's through the Klipsh speakers is a real "front row" concert experience type of thing.
For those that missed my 300B thread on DIY this is the link.
http://www.audiokarma.org/forums/showthread.php?t=224767&highlight=300b+set
Scan down a few posts and you'll see pictures on the finished projects.
Voltage change was from going from a 5uf input cap to a 15uf input cap, voltage
raised 7v, and a drastic change in the performance of the amp, from say 250v to
330v EL84's an 6V6's respond a fair amount to voltage increases, I found this out
some time ago with multiple amps. (also they don't like low screen voltage either)
I use decent size capacitive tanks on the section feeding my outputs, this makes
a stiff supply that does not sag/drain the caps on transients, upping that amount
on a vintage amp that usually has small capacitance there's usually a big upgrade.
(generally has a larger improvement on the bass and authority of the amp)
I generally use "higher" GM tubes with lower plate resistance in my designs as well.
Also I find a lot of vintage amps the drivers are starved of both voltage an current
so upping there voltage to them is usually a bonus as well, running a driver on less
then 100v is quite common and I've found just getting it over the 100v mark is the
place they start to open up an perform better. (different tubes different voltages)
One of my friends has a CJ Premier 1 and 2, His power amp was switched from 6550's to EL34's but after going thru hell with the 6550's which he down right deplores from screens arcing over and such he just loves his 6CA7's.Could you run the amp with the resistor, record the B+ voltage, then clip the resistor and run the amp on a variac to get the same B+? Would that be a better test? All this talk about tubes liking higher voltages has me thinking about 6CA7s. They are rated at 800volts (plate), and most amps barely run them at half that. ??:scratch2:
Yep, and this is the problem with "most" mods. It's very hard to A/B stuff. I mean, how many people have configured an amp with a switch to change between Riken or Allen Bradly resistors, so they could be properly A/Bd? Nobody that I know of.I guess that why shiny stuff sells so good to mod freeks.
It seems like the longer I'm in this hobby, the less shiny stuff I'm buying.
He also loves KT90's as I do and of course the KT88's are a fav of mine. My least favorite is the 6550.
Problem's not the 6550... at least it's not a fault of the tube ITSELF.
It's the fact that the CJ amps are running the screens at nearly 600V (around 575V on most)... on a screen rating of only 400V on the 6550!
These amps should have been specified for KT88s from the beginning... 800V plate, 600V screen. Also with enough plate dissipation that you can bias them up rich, and still not red plate (35W for the 6550, 42w for the KT88).
The EL34 will "get by" if you bias it low enough (also rated at 600v screens)... but the REAL solution is the KT88. Or the KT90, as mentioned... it will also readily handle the screen voltage (rated 600v on the screens)...
So, it's silly to blame the 6550 tube... when the manufacturer knowingly built the amp where it was running it outside of spec...
Regards,
Gordon.
Same thing with a lot of VTL amps.
I redid one a bit back that was running 600v on both the plate an screen using EL34.
Yah it worked but would eat tubes an only certain brands would take it, It was fixed
bias so all the voltage was on the tubes, I modded it for cathode bias and left just a
touch of adjustable bias left to balance the 4 tubes, now it runs KT88 at roughly say
550v plate to cathode, much safer operation, also now triode instead of pentode.
