Hello Dave,
Thanks for writing. I'll be starting on the second unit today. Stripping and cleaning first.
I have a safety related question. On this amp I drilled out the RCA jack opening and installed an isolated jack. So far I haven't connected the audio ground to chassis. There is a power cord chassis ground to the green wire. Do I need to connect audio ground to the chassis or is it ok to let it float? I've seen articles about using a bridge rectifier with a resistor and cap as a ground break. Since these are for a friend, I can't be certain how they will be used in future and want them to be safe but not a cause for ground loop problems as well.
Thanks,
John
