For this project we're using a Pioneer DJM800 mixer (This is a mutil-thousand dollar 24/96 digital mixer with competent phono preamps) so working with how the mixer loads the cartridges, the ones that move effortlessly between analog and digital are Stanton 890AL, Stanton 500E Mk2, Ortofon Concorde with OM10 stylus and the biggest surprise, the AT VM95C which handles and sounds great at 2.5 grams, and cost $35 delivered. The Stanton 890 sounds great but almost always sounds better than digital, bigger, more dynamic, clearer, etc., so that's a no-go. The Stanton 500E allows effortless movement between analog and digital sound wise but finding original styli is much too tedious for a production environment in 2021. The Ortofon Concordes with DJ styli handle great but are brutal on records and their sounds is way off the mark, typically a dB or two brighter/harsher than the digital files The unique Pro S stylus sounds close-ish but the stereo image is collapsed and in comparison to digital sounds both harsh and missing detail/articulation . The Om 10 stylus sounds perfect but is a non-starter as far as handling. I have tons of different Shure cartridge/styli combinations domestic and DJ, and they range from ok to amazing but only the V15V (original, NOT the x version) with an oem Shure conical sounds like the digital files, is much too fragile for broadcast use, and styli are impossible to find.Which pickups and phono preamps are you using with the 1200s?
Digital path is spdif from Automation Megaseg on Mac to mixer. NO dsp or processing happens at the Mac or in Megaseg, its 1 to 1 digital playout of uncompressed files to the mixer, thru the mixer, and into the broadcast encoder. Audio path is 100 % digital and only becomes analog at the listener's point of play back. In the venue, the digital output of the mixer goes AES to the venue Soundcraft console and that system is all digital as well so its a clean feed with no ground loops, cable loss, console preamps, etc. in the audio path.
