Well between work and family, I am falling behind in this thread - and since I started it that's pretty bad. I was only able to listen for about 20 minutes last night, and it wasn't nearly long enough I can tell you that. I will get some more time tonight I hope, and I'll try and answer everyone's questions.
A few thoughts initially:
1) HiFiDo really knows how to pack. That said, the dust cover still sustained a small crack near the back corner. I'm working that out with them now.
2) The auto-lift doesn't work at the moment. I need to remove the tonearm and see what's going on under there.
3) Shipping was a little over $300 to the Eastern US. Not cheap certainly, but where else are you going to find one of these ? I gave up waiting on Agon.
4) It's sure a heavy beast, but so is the VPI Classic. Moving either around really strains the back if you're not very careful.
5) Just like Theo did, I removed the headshell/cart from my PX2 and plugged it right in. Even the 50mm offset is the same and checking with a protractor from vinylengine showed everything looked good. I will get my buddy's OmniDisc soon for a more careful dialing-in.
6) I wish I had two identical carts and two identical phono sections so that I could give accurate A/B comparisons to the VPI. But I don't, so I think my comments from here on out may say more about the cart/pre differences as compared to the tables. Please keep that in mind.
My son and I played some classic rock and damn, the bass is sure there in spades with this table. Stronger even than the already solid PX2. More time and music selections are required before I can say much more about the sound than that. It certainly doesn't suck
So far, no regrets and it looks...well pretty bad-ass
. It's every bit as imposing as the Classic in that regard.
more later...
jblnut
