Bradbrews
I picked one of these up, and have been using it for a week or so now. I'm only using AMHD for streaming so far. To help me get a feel for what is really going on with the various streaming options, I ran the output of the unit into a pc and an M-Audio 24/96 card so I could see its spectrum while streaming.
I can get CD quality when using iphone>Airplay>Keiid. However, when I use Muzo, or Audio Pro, though both have AM support, I get a audio that maxes out at 17kHz, with only occasional blips up to 20kHz. This is a typical pattern seen when a compression program (MP3) is in use. This confirms what chicks saw with the data rates from the router. I can post some pictures of the audio spectrum's as soon as I transfer them. There was some visible noise in the output spectrum when the unit was paused, but I didn't take the time to check whether that was from the Luxman R-351 preamp, or the Keiid. The sound quality between Airplay and the Audio Pro (I also don't care for the spinning art on Muzo) are both very similar. M Connect does not support AMHD, and I haven't tried any other control apps yet. Airplay requires me to adjust the volume up a fair bit, vs AP, so a back to back comparison is kind of difficult. Compared to my oppo CD though, both are a bit behind. I have not had a chance yet to try out the digital output into an external DAC. I suspect that there are improvements to be had there. The unit did a firmware update when I got it, but though I hoped that would have been the thing that enabled AMHD, it wasn't. Overall, for $62 this is a good unit. If it ever gets a update to support higher quality audio it will be great.
