BUT the SM states:
R549 56,000 ohms
R547 47,600 ohms
R548 47,000 ohms
R550 56,000 ohms
Emitter resistors test ok (not open)
FR503, D509, 511, R531, R543 seem ok
R547 and R549 are in parallel, also in parallel with C515.
In circuit measurements can be tricky due to alternate paths for
(MM) current flow. When you attempt to measure you are measuring
the total of the 3 above components, ie, 47k in parallel with 56k
gives 25.5k then in parallel with C515 gives??? Also note that
R547 and R549 gives the same result (16.6k), no issue there.
C523 tests ok however I'd replace since you've removed it, MKP or MKS film
I'm not seeing how -I can be +4.7V to +8.7V. The obvious path is via +I and
the bias cct. Double check voltages at +I and -I, monitor voltages for 2-3 minutes
careful with +/- sign.
Maybe consider replacing TR519 2SC1953 ecb with KSC3503 ecb.
Monitor voltage at D511 anode (TR519base)
