Hifibythekg
Update:
The amp was functioning and sounding very good..
Fitted the Bourns trimmers, wonderful improvement!
Power supply reads 35.2V
DC offset 0mV and stable.
Two problems:
1.
The left channel made a slight static scratch when either the ‘tone defeat’ or the ‘Disc’ was pressed on and off.
Then.. it made big scratchy sound on the left speaker.., I switched off the amp, and now the power button lights up but the speaker relay won’t activate.
What should I probably check for first?
Just prior to this however..
2.
No idling current adjustment on one channel.
Between TP2 and TP4 I can set a stable 7.4mV
But between TP1 and TP3 it’s about 0mV. No amount of turning the new pot will affect the reading.
Thought it might be some bad contact with the DMM but turning up the volume makes the idling current immediately climb up into the teens.
Have already changed TR 137 and TR138 from a 2SC1213A to a KSC2383, and TR 139 and TR 140 from a 2SA673 to a KSA708C.
Diodes 103 and Diode 104 replaced.
Checked solder joints.
Any suggestions anyone?
Two problems:
1.
2.
Chinese are the worst..
