NumbDiver
Now back to the Yamaha, lets not get to over board about the B1 being something like the best thing that ever came to audio, there were and are many other amps that I think would better the Yamaha and they don't use V-FET's.
I would argue that the B-1 (and B-2) truly are one of the best SS amps ever. Especially if you consider the price. If we use round numbers and say the rebuilt/recapped/factory spec’d B-2s are around $1k and B-1s are around $2500; there are few amps that will perform better in either category. Sonically, they are reference grade (when refreshed). Yes they are vintage and the switches can be a PITA, and the binding posts are not up to today’s standard. But…
Take a look at the scientific papers (test sheets) that Yamaha released with the B-1 and B-2. The vfets are special indeed. As the only sand outputs that have similar response curves as triodes; they can do things others (bipolar/mosfets) cannot. They are highly linear, very low distortion, AND very fast switching devices. The square wave output of the Yammy vfet amps may well indeed be bettered by a Halcro, but at TEN times the cost. And all said and done, the Halcro* sounds ‘sterile. Not so for the Yammy. There is a reason so few manufacturers give the kind of test info that Yamaha provided with that particular genre of amp. Yamaha knew full well they had something that nobody else could touch. Sadly the vfets were grown in-house and were expensive to produce.
The B-1 uses only one-pair of (huge) output devices for each of the +/- of its push-pull design. They are basically like push-pull triode amp with silicon tubes for outputs. And the outputs perform as such. Lots of protection circuitry, but the signal path is quite simple. Nelson Pass I believe will go one step further and run them single-ended (with the SIT/vfet devices he had manufactured for himself). THAT is the amp I hope to live with, in the future. A silicone SET with a freq response as linear as a tube triode.
If the right guy came along that could do it (as I would assume Mr. Pass wouldn’t do it for me); I would maybe be willing to cannibalize (yes, destroy) one of my two B-1s, to use the outputs in a single-ended version of a vfet amp. I think our own Unda Marais would have the skills to build one. Man…that could well be a world-class amplifier if done right. Thankfully Mr. Pass is going to do it for me, and my B-1s can remain intact.
But I digress…yes; Yamaha’s vfet amps are ‘that’ good and can easily keep up (or trump) more modern designs. Especially at their price.
IMO.
*I haven’t auditioned the big Halcros, but everything I’ve read says they are very analytical in nature
, but I see a few under-voltage situations that will not allow the output stage to be energized.
