PioneerPro
Yes the power was on.Please clarify, did you take the following measurements with the unit powered ON?
Correct but did you look at the schematic? It shows a line between ES and E. Why is that line solder bridge there? I did not put it there. Do I need to remove it?As a general rule, such solder bridges must be avoided/removed. You are lucky in this case since the ES (speaker GNDs) later connects to the other E/GND pins so no harm.
I addressed that in post #143. I had removed one end of FR701 and FR702 and ran resistance tests on them. TheAssume unit was powered on.
Indicates FR702 or FR701 or D701 has failed.
Resistance check FR701 and FR702, unit powered off
Clive, Iowa. It's a rich suburb of Des Moines. LOLTotally understood, I'm not even sure which time zone or area the OP is located.
Im guessing west coast USA?
