Bad idea...You can not rewrap once unwrapped....How many wire wraps have you screwed up ? Just that one ?Hey everyone, I've been away from this project for almost 2 years, but I'm back at it now and want to get it finished. However, I've run into a snag. All of the interconnects in this receiver are wire wrap connections, so I decided to get a wire wrap tool so that I can unwrap, and then rewrap the connections to each board. The unwrap part works great, but it turns out the wire Yamaha uses inside this unit is like a soldered speaker wire, and it doesn't rewrap well at all. Now I'm looking for an alternative. I don't really want to use solder so I'm looking for some sort of header pin connector. I thought the connectors like the ones used in computers might work, but they're too small. does anyone have a suggestion for what to use to reconnect these wires. By the way, the pins measure 1.00 mm, see the photo below.
Thanks,
Rick
If you need think you need to get wire wraps off the board. Unsolder the wire wrap header from the circuit board and leave the wire wraps unmolested.
