Two options..Trim the lugs or enlarge the PCB openings.Looking for idea and suggestions.
Check your grounding scheme on the equalizer board. Are you using MM or MC ?This hum is only there on Phono,
You likely have a broken connection to the HP jacks or a cracked PCB in that general area.Or the phone jacks are both broken.
Do you hear it if AUX or TAPE is selected ? Does this sound like crosstalk ?Ok, so I've been listening to the Yamaha for over 2 years now, man how time flies! Last week I put headphones on to listen and I heard a not so faint noise (white noise?) coming from both channels. I fiddled with the controls and the noise volume stayed constant. The volume and balance controls had no effect, and the noise was constant as I selected different inputs, even muted FM. Now when I listen to the speakers with no input source I can hear that same noise, faint but definitely there. I need to open the receiver to try to clean one of the selector switches better and I want to look for the source of this new noise. Any suggestions?
Thanks,
Rick
