Specs are only important in the sense that it gives you an overall idea of whether it will fit into your system.
For example:
If I have a very large, hard to drive pair of speakers that are rated at 83db @ 1W/1M with a nominal impedance of 4ohms and my preferred listening levels are at 90+ dbs average in a 600 cu/ft room, sure absolutely I won't be shopping for an amp that produces 20wpc @ 8ohms.
If my intentions are to listen to hi-res audio at 24/192 as well as DSD files, I won't be shopping for a 24/96 DAC.
Beyond a general overview, you can't decipher how a component will sound just by looking at a spec sheet nor can you get an idea of how a speaker will sound by just looking at an anechoic frequency response chart.
Nobody mentioned that you need to spend tens of thousands of dollars to get satisfying sound. I too, have heard amazing budget systems that were well put together that have sounded better than poorly matched systems that cost 10 to 20 times more at various dealers as well as audio shows. At the same time, it doesn't necessarily mean that the individual components in the budget system are better than their more expensive counterparts though.
Personally, if I had $80,000 to spend on an amp, it wouldn't be the Ongaku either but I would spend far more than a $1,000.
Specs should be important Brother, otherwise we would all be bragging about our latest GPX or Soundesign score. My point in my original post is that you don't have to spend $8k to get good specs and performance. I have seen used systems that Brothers have less then $500 into that blew me away with how nice they sounded. If you have the money, by all means spend it on what you want
Would I spend $80k on a tiny amp? No, I would spend a grand+ on another WOPL and save the rest
