I'm thinking of building the Z19's but I have JBL 2235's, will the LF section have to be different?
I started athread and today realized it would be better here. I deleted the other thread.
Here is the beggining of my z29 crossovers I am building.
I do have a question about the bi-amping part of this crossver.
It seems to me that it would be better to get the signal from the pre-amp, then feed it into the crossover. Once the crossover breaks the signal into the low and high, feed those signals into the amps.
That make sense? I'd rather do that than feed a full power signal into a the crossover and let it do its thing. I think an amp would be more effeciently utilized if it only had to work on a high or low signal.
So the question, will this change the crossover? I think crossovers are designed to work with a certain impeadance driver, SO I don't think this would work but I would love to hear from the gurus on the board. What d0 you think?
Mark
The short answer is yes, you'll need a line-level crossover. Those can be passive or active, and active can be op-amp based or DSP based. Here's a good primer on bi-amping:
http://sound.westhost.com/bi-amp.htm
Cool!
See the top-right L-pad notations on this drawing:
BUT I see no reason on earth to retain the confusing "G, 4, 2, 1, and 3" designations. I suspect Zilch did that because it made sense to him for other reasons. I think it would be much clearer to discard those designations and simply to label the five points on your top right terminal block as shown in the notations on the margin of the drawing above, that is, M1, M2, H1, H2, and H3, then run those terminals to the corresponding posts on the Mid and High L-pads. That's how I marked my boards.
I thought that I would ask a more knowledgeable group about these Z19's. I read a little bit of conflicting data on this and wanted to make sure that I was doing it right.
If I'm combining two non polarized caps together (example a 20 and a 1 to make a 21), I need to wire them in parallel (same ends together) and not in serial - correct?
The short answer is yes, you'll need a line-level crossover. ...
