I'm interested in building the econo waveguide speaker.
I have a pair of Eminence Kappalite 3015LF woofers. Will these work well, or should I sell them for something different?
I pasted the woofer specs below. Which crossover should I use with these?
I like my speakers a little on the bass heavy side. I'll use the speakers primarily for home theater. I listen to mostly rock, but also enjoy jazz.
I will be building my own speaker enclosure from MDF.
http://www.eminence.com/proaudio_sp...=KAPPALITE3015LF&speaker_size=15&SUB_CAT_ID=3
SPECIFICATION
8 ohms
450W
Resonance 42Hz
Usable Frequency Range 40Hz-1.5kHz
Sensitivity 99.8
THIELE & SMALL PARAMETERS
Resonant Frequency (fs) 42Hz
DC Resistance (Re) 5.31
Coil Inductance (Le) 0.92mH
Mechanical Q (Qms) 6.82
Electromagnetic Q (Qes) 0.41
Total Q (Qts) 0.39
Compliance Equivalent Volume (Vas) 158.8 liters / 5.6 cu.ft.
Peak Diaphragm Displacement Volume (Vd) 846cc
Mechanical Compliance of Suspension (Cms) 0.14mm/N
BL Product (BL) 18.6 T-M
Diaphram Mass inc. Airload (Mms) 101 grams
Efficiency Bandwidth Product (EBP) 102
Maximum Linear Excursion (Xmax) 9.6mm
Surface Area of Cone (Sd) 881.1 cm2
Maximum Mechanical Limit (Xlim) 17.0mm
