hi... first post after several hours of reading...
i was pointed over to this thread by a kind poster over at avs forum...
here is the link to my thread there, and what follows is my original post/question from there...
disclaimer: i know nothing about designing a "speaker" from scratch, so be gentle, and use little words...
i recently acquired a seeburg trashcan jukebox (1948):
not in that condition, sadly... mine can be (generously) labeled as "restorable, with most pieces there"...
anyway... the intention is to gut the entire thing, make the outside pretty, make all the lights and buttons work and turn it into a cd changer/ipod dock... get a used/cheap pro amp and toss that in for power... add volume control... that part is pretty much figured out...
but for the speaker or speakers/xover, i'm lost... i'm thinking that it shouldn't be too difficult to come up with something better than what is in there now (standard big jukebox driver)... but i have no idea where to start...
so, i need a solution, and i'm hoping that someone (or ones) will be willing to help me out...
i'm "guessing" that i'd want it to be mono, because i don't really think stereo "works" co-located... but i'm open to be educated on that...
there's a lot of room in there... for comparison, i'm looking at my 15 inch paradigm sub, and it would fit in there without a problem... it could even be another 8 inches or so taller... i can modify the front door if necessary to make more area for the speaker to fire through (the current hole is the size of the existing speaker)... i can also fabricate a shelf/mount to securely mount whatever you come up with...
keep in mind that while i'm pretty good with electronics, my woodworking skills are about the level of "can cut wood without losing appendages"... obviously it doesn't have to be pretty, since once inside the jukebox, no one will ever see it... but if there's any difficulty involved, i'd have to have it built for me... a man has got to know his limitations...
as far as budget goes... how about $500 to start, counting everything i'd need (including having the cabinet made if necessary)? i have no idea what a "good" diy speaker "should" cost...
i can easily move north of that number, but i don't know where diminishing returns start to kick in...
it would be nice if it would play loud enough to fill a reasonably large area (about 17X40), but also sound good when played at a low volume...
edit: when i say "fill", i mean "can hear it in the background", not "blow my ears off from 20 feet away"...
anything i'm missing? any other info needed?
thanks guys. i know you'll come up with something good for me...
