My question is would these make a good beginner E-wave?
Would that 12 inch woofer reach high enough to work acceptably with the horn/driver selection?
Most any 12" woofer that is not designed as a subwoofer will play high enough. If you like the bass those speakers make, then go for it.
You don't have to do anything to the Yamahas to verify that the combo will work to your liking -- merely bring out the woofer leads and connect to the eWave driver/waveguide/crossover and listen to how it will sound. If you like the result, then you can commit to modding the cabs as required to complete the build. :yes:
I don't really know all of the terminology and implications of the graphs (which is why I am happy to have people like you on board!). What does this mean for the design/build. I currently have the front of the waveguide even with the front of the baffle.
Any two drivers that are spaced some distance from one another will interfere with each other when playing the same program material. In any multi-way speaker, the drivers are doing that in the crossover region. The interference is manifest as a cancellation, i.e., a dip or notch in the response, whenever the distance from the listener (in this case, the measurement microphone) to each of the two sources is sufficiently different to generate the interference.
In designing the crossover, we "steer" the forward (non-interfering) axis such that it is aimed at the typical listening height, above and below which a characteristic interference pattern progressively develops with greater displacement of the listener from that axis. Many factors limit how much leeway we have in accomplishing this objective using passive crossovers with reasonable numbers and cost of components. Generally, I try to achieve a symmetrical pattern about an axis aimed somewhat upward from the midpoint between the drivers as reference.
Once I saw that your waveguide was more aligned in a vertical plane than mine, I adjusted the filters to achieve essentially the same flat response at a lower angle. You can see that the acoustic crossover frequency went up a bit in the course accomplishing that. My waveguide flange is 1.75" ahead of the woofer flange, and moving it back would aim the axis correspondingly higher. It's trigonometry at this point; the measurements indicate that we have a +/- 12.5° "window" within which to work before the interference would become audible.
I doubt that you'd even hear it, in any case, as notches are less sonically apparent than peaks. If so, you may want to move the waveguide forward on, for example, a 1" - 2" frame behind its flange. In many builds using the QSC waveguide, we've been rear-mounting the woofer on the baffle to assist in achieving the optimum alignment, but that's not an option here. You can see in the curves that constant directivity is working nicely throughout the balance of the spectrum.... :yes:
