DonQuixote99
just give me some truth
The woofer with the "RW" in the cone number is a recone (that's a Waldom number).
It appears to be the correct cone, though, so no worries.
Regards,
Gordon.
That's what I wanted to hear.... Thanks.
Regards,
Gordon.
Group buy for badges available to subscribers in bartertown now!:
http://www.audiokarma.org/forums/showthread.php?t=358179
bwaslo, you do not have permission to access this page. This could be due to one of several reasons
It's because of "available to subscribers" (the PS of my previous post should make more sense to you now).For some reason, AK won't let me go to that link
The 2.1 mH and 7 ohm values are measured from a model 14 woofer.
The .155 mH and 6.8 values are measured from an Altec 902 driver.
The 25 uF and 10 ohm resistor are the Zoble network.
DE250 is 2 or 3 bolt driver while D220Ti is 1-3/8" thread. Are you planning on performing surgery on the waveguide? (It's been done before.)
Hate the idea of spreading wrong data.
Wank Spreading
We can have no "Wank Spreading" here!![]()
hey guys - can someone point me to modding the jbl waveguide for bolt on? I have the adapter already but would like to get rid of the throat if that will improve things.
You'd have to replace the woofer on the CS-77s, probably. It was crossed to the mid-range at 450 Hz, which suggests to me it won't go nearly high enough for an e-Wave.
Old two-ways are in general good candidates; old 3-ways, not so likely.
The E-waves have come back from the disabled list. I got the replacement D220Ti diaphragms from PE yesterday, so I was able to put them back together!
Once again they're set up in their proper domain, and breaking in the new diaphragms and caps. It's interesting, when I first built these, I remember they sounded pretty raggedy for a little while. These don't sound raggedy much at all, I'm really looking forward to seeing what the well-damped diaphragm back can do with the charge-coupled crossover.
So far, the damping by itself has made a huge difference with the D220Ti driver. It's highly recommended to everyone who uses them.
