LE14A bass is simply NOT gonna happen with stiff surrounds, so y'all may be jumping the gun on listening to these.... :yes:
E'Wavers are certainly a wordy bunch.:
Rollin' over 50,000 views here, momentarily, as well.... :thmbsp:
:beer:
There was a HUGE difference in the bass output when mine were refoamed. The original owner thought they still put out great bass. He was used to the sound deteriorating over the 25+ years he owned them. When I got them home I thought hmmm, there's no bass. Shouldn't a 14" JBL woof have bass? They will have plenty of bass after the refoam. :yes:Well, there certainly seems to be more than I'm used to already, so I'll give them a shot as is, and then give them the brake fluid treatment until the surrounds from Rick arrive..
Careful, now, use a brush and don't get any on the cone; just do the "groove" of the inverted roll. :nono:Give um a lube before yu run off to work, let um sit a while.![]()
Well, I forgot I needed to tweak the crossover from 16 ohm hi eff woofer to 8 ohm under 95 dB ones, so that's more than I can handle tonight.
It's like Wayne's issue with the lower vertical null occuring at the ankles with the Summas. Could that be improved? Of course. Will it make a bit of difference in performance when used in the recommended position? Uh Uh.![]()
It's absurd. You MUST be on-axis vertically, but you CAN'T be on-axis horizontally? It appears to be a tortured rewrite of listening practice to conform with a compromised waveguide design he can build in his garage.Earl repeatedly says his speakers' vertical performance is better than most. That's rubbish. Their verticals are worse than most I've seen.
When I pressed him on the issue, his response was, basically, "Why should I build something less than perfect?"He admits that it would be better to have closer-spaced drivers, a limited vertical pattern and wider spacing between vertical nulls. These are all things that an asymetrical flare can provide. But then when pressed to move in that direction with his designs, he says he is unsure how much benefit it would bring.
As side surrounds, yes, absolutely! :thmbsp:Zilch, if you had dipoles would you listen in the side null and expect good performance?
Yes, as I understand it.... :yes:Is the ideal placement of nulls always just outside the horn pattern? e.g., placing nulls just outside +/-25° is taken to be ideal for econowave which is a 90°x50° horn; if using a 90°x70° horn, would the ideal placement of nulls be just outside +/-35°?
Gedlee said:The axial hole will be diminished by an elliptical waveguide because the edge diffraction can now no longer be in phase on axis at any frequency. If the mouth is round then it can. There is nothing magical about round except for a few points:
1) the woofer is round
2) making an elliptical mold is extremely difficult
3) the compression driver's throat is round.
Elliptical is certainly possible to fix the hole, but the hole is not really a problem so whats the point of fixing it?
-7.5° doesn't seem too good for a vertical null. is that the result of crossover frequency selection and driver spacing or is it an electrical phenomenon (i.e. retarded phase in the hi frequency driver) which is steering both nulls up?
also, is the ideal placement of nulls always just outside the horn pattern? e.g., placing nulls just outside +/-20° is taken to be ideal for econowave which is a 90°x40° horn; if using a 90°x70° horn, would the ideal placement of nulls be just outside +/-35°?
http://www.diyaudio.com/forums/showthread.php?postid=1516151#post1516151
I'm looking for the paper showing the early elliptical design exhibiting the anomaly....
