wiredbecker
...jams ECONO!
I was doing box tuning measurements and leak tests on Wiredbecker's C36s last night, and listened for several hours:
Augh! I bet they're sounding even more amazing and I'm bummed I wasn't there to listen and assist.
As a start, we generally look to how JBL used a particular woofer in their product(s). In the case of 2214H(-1), two examples come immediately to mind, L100T(3), a tower similar to what you prefer, and 4425, a Studio Monitor with compression driver and horn. Those define a range of known suitable cabinet sizes, and with inquiry, their tunings may also be determined.Apologies to Jack et al. But I am getting somewhat confused. Reading about 200 posts we have volumes of 3. cu ft to 3.8cu ft but in post 599 or so we are given 1.6 cu ft.
Kegger:
Glad to hear you are sorting out the mids.
How did you come to those values?
Rule of thumb? Or some calculator? Or doing the math?
You sure your decimal point is in the right place?![]()
With a Zobel being used from the calculated values I've now lost bass, or more appropriate gained
frequencies above bass which ends up accomplishing the same thing,also the HPM woofer really
doesn't "need" a zobel filter (if it is what the published graph shows anyway) so I'm gonna do some
"altering" and try a larger resistor then what was there and go back to a larger cap but not quite as
large as what was there before to see if I can shape the impeadance a little more proper and get a
bit of the bass back as well. We'll see. :scratch2:
Also the Xover is now 1.2kHz?
Thanks for help. There are just too many posts and my inernet speed is 26.6k
so quite a pain to go looking for stuff.
I got the Selenium 210's and the crossover parts will be here on Tuesday, and I ordered the waveguides a week before last Monday and they still haven't went through my credit card yet(They were out.):thumbsdn:
I want to use a pair of Marantz 7 MKII's for the woofer and cabinet, but I don't know the efficiency rating of the Marantz woofer. I know its a long shot, but does anyone have a clue? I could post some pics later if it would help. Since the bass overwelms the top end quite a bit, I'm wondering if they would be higher than 95db. I ordered the regular 8 ohm crossover parts so if the Marantz are no good I have a pair of LA's and NLA's I could try it on.
Any input? Thanks.
Thanks for the suggestions Gordon.
The problem is I'm not wanting to drop off the top end of the woofer further, I'm using a
1.5 mh coil and 8 uf cap, my feeling is if I use a larger coil I won't be able to use a smaller
cap to get my top end back. I think I am pretty close now and just want to attenuate that
upper end of the woofer and not roll it off any earlier. Is there any tricks I may not know of
for accomplishing that?
The zobel seems like a solution that could work here, and if the impedance graph for an
HPM woofer is correct and I use say 12-15ohm resistor and it will attenuate enough then
it looks like it just may work for both impeadance and frequency with a large enough cap?
I used the 8 ohm crossover parts list. The under 95db one.
Give 'em a little call on Monday to "Expedite."I got the Selenium 210's and the crossover parts will be here on Tuesday, and I ordered the waveguides a week before last Monday and they still haven't went through my credit card yet(They were out.):thumbsdn:
:lmao::lmao::lmao:[There's apparently been an extraordinary demand for these lately....]
Hi Sheldon,
Since this thread is about doing it yourself, I didn't just give you all the details about using 2214H's in my EconoWaves. For most guys, searching and discovering is half the fun. But since you are speed limited, let's just cut to the chase.
The cabinet size of 1.6 Cubic feet was in post 594, and concerned a pair of EV Baronet clones that were built a few years ago. They became my next EconoWave project with LE10H woofers. Ignore that value, since the 2214H's were not used in those cabinets.
The 2214H's were used in another pair of EV Baronet clones that were built after the original pairs, and they were built roughly 1.5 times original size. In post 504 I said if my memory was correct, they were about 3 cubic feet in volume. In post 507, the volume was calculated to be roughly 3.18 cubic feet, allowing some fudge factors for various things inside the cabinet. Use that number if you want to duplicate my results.
The cabinets were ported through the front, and were tuned at 38 Hz by two ports 3" in diameter and roughly 6 inches in length. See post 507.
The LE14A and 2214H both liked a low pass frequency of 900 Hz, rather than the 1200 Hz used for most other woofers. For correct crossover values, see post 228, and select the Variant 2. option, which is for the JBL LE14A. Also add the two 100 Ohm 20 Watt resistors across the 2214H, as JBL did in the 4425.
When you get your cabinets designed and built, please let us all see some pictures.
Dam I hate sibilance, I think these frickin kimber kaps I put in the high pass section are the
culprits as it wasn't there till I decided to "upgrade" the "quality" of caps in the xover since
I had them here. UGHH!!
Just sitting at my pc not even in the same room as the stereo all I could here is SSSS, SSSSS! AAHHHH!!!
Time to do more digging, may resort to the giant oil caps I've been stashing away, but man there biggins!!!
