I presume you saw where Jack's reworking Seville baffles to fit E'Wave in the cabs:meanwhile, my green horns sitting on the side....
I read somewhere that somebody's making them. In the AK K forum, perhaps, or the factory main one?in a meantime - anyone know some good reference for DIY-ing matching xformers , as found in KH xovers ?
[We don't use bad words here....]
, but - besides some Yidish word ( one crazy preamp there is named exactly with that word ) , I don't use any other "bad " word on net .....
WOW do these sound GREAT!!! I replaced the Passive radiators, mounted the new crossovers, and fired them up. They are fast, detailed, dynamic, and have bottom end that won't quite. The only problem is that the left channel is set at full volume on my 300B amp and the right channel is set and 3/4 volume just the get them balanced. I switched everything up and the only thing I know now to cause the reduced volume is the left crossover. I built them identical. So what would cause this problem??? P.S., I am running the horns with a 300B amp and the woofs with an Adcom GCA 510 amp. I will refinish the cabs and the grill frames in the weeks to come.
You switched them and the problem followed the crossover?I switched everything up and the only thing I know now to cause the reduced volume is the left crossover. I built them identical. So what would cause this problem???
[The Zilchster scores a big ol' "DUH!"Zilch, I am not using L-pads because I am bi-amping and both amps have volume controls.
