12" Shiva #121947 dual vc driver
bolly
Lunatic Member
Banned
seen a couple of these in a 2'x2'x2' enclosure, very solid probably 1" MDF. Not bad lookin either, about 100lbs each. Anyone know the deal on these Shivas's?
Shivas are pretty well regarded among the DIY crowd as a great bang for the buck sub driver. Not the greatest driver ever but really hard to beat for the price.
not much room at my place
$100CDN for the pair, with cabinets. What would you do?
a pair very similar to those
wow gary, nice sub! You have the passive with yours, none on the ones I seen. Just the woofers.
No passive on mine.
I use it more for music than theater stuff. That is the type of enclosure that Adire rec for me.
Gary
I think I'm convinced, all I've been thinkin about
the guy's open tomorrow, I'll reinspect those cabinets...make sure they're of a high quality construction, see if I can test-run em. Would it be ok to run them full-range, just a little bit?? :scratch2:
bolly said:
what's the deal with the 2 sets of voice-coil leads per driver?
Here's a question for you, bolly: when they call it a 'dual voice coil' driver, what exactly do you think that means? :scratch2:
Two voice coils, either 2x8 ohms, or 2x4 ohms, depending on the model. Two voice coils means two sets of tinsels.
Here is a page on the Shiva subwoofer drivers.
You can either hook them up to stereo amp outputs or you can wire them in series or parallel to a mono amp depending on what impedance you want.
I mean, the 4 wires off each driver. Do I just hook up two, or tie both +ve's and -ve's together.
bolly,
Go here - http://www.bcae1.com/
go to link #58 on the right, about half way down is all the different wiring schematics you could want for dual VC's.
:thmbsp:
I know for car audio dual voice coil subs are for the low end of BOTH channels so you can have your stereo image and your stand alone Sub too. Kerwin-Vega used to make 'em especially. I always thought thay it was kindof a crummy shortcut to a well designed system. Not sure that applies here of if it's any help at all, but I got my two cents in!
