Not really.Not sure if they are interchangeable? Limited research appears that they are direct replacements for el34. Maybe depends on the amp? Anyone have experience or knowledge that I lack? Thanks in advance!
Thanks for all the info. I will not use it for my el34. It’s too nice an amp to risk. I do have an integrated that takes 6L6GC/5881. $50/quad from a seller I trust. A good alternative to new manufacture tubes.The 6P3S-E is NOT equivalent to a 6L6GC. It won't manage 30W anode dissipation, nor have I ever seen reliable specifications for screen grid dissipation or voltage. Reputable sellers only rate it equivalent to the 5881, and it was relabeled and sold as this type for a number of years. The 6P3S-E is also not equivalent to the EL34. There are a number of significant differences, such as transconductance, voltage ratings and optimum load impedance. I know it's been subbed for the EL34 in certain amplifiers (including the Dynaco ST-70), but there are reports that this produces a different sonic signature and reduced performance.
Just to be clear, I'm a big fan of the 6P3S-E, and I bought a large lot directly from Russia quite a few years ago. It's a terrific tube that can sub for many 6L6 variants in many different amplifiers, but it's important to know its limitations. I use them in my Citation V, but the amplifier has been modified for reduced screen voltage. I'm also careful to bias the tubes below 25W dissipation.
Jack
That's a great deal if they're matched.$50/quad from a seller I trust.
Were they 6P3S-E? Some of those will have slight gas that can be burned off using a variac over a period of a few hours. Of course, some will also be a lost cause when this happens. Maybe I've been lucky, but the Russian sellers I used years ago were willing to exchange the tubes I sent back, and that was before shipping cost became so significant.There's only one Ukrainian seller I trust. I've bought enough power and octal signal tubes from him over the last few years and never a dud. The matche'd quads and pairs have always been very close too.
I made the mistake of ordering a few tubes from a other seller and got two duds that red plated right out of the box.
Pulled the trigger. + a Hamilton for shipping. I was wrong they are NOS. If these are close to my GE 6l6gc I will be on the lookout for more!Were they 6P3S-E? Some of those will have slight gas that can be burned off using a variac over a period of a few hours. Of course, some will also be a lost cause when this happens. Maybe I've been lucky, but the Russian sellers I used years ago were willing to exchange the tubes I sent back, and that was before shipping cost became so significant.
Jack
No, these were some 6P14P-P's. I haven't had a problem with the 6P3S-E's, or the Russian versions of the 6SL7's or 6SN7's, and 6V6's.Were they 6P3S-E? Some of those will have slight gas that can be burned off using a variac over a period of a few hours. Of course, some will also be a lost cause when this happens. Maybe I've been lucky, but the Russian sellers I used years ago were willing to exchange the tubes I sent back, and that was before shipping cost became so significant.
Jack
Just curious, which amplifier are these for?Pulled the trigger. + a Hamilton for shipping. I was wrong they are NOS. If these are close to my GE 6l6gc I will be on the lookout for more!
Raven blackhawkJust curious, which amplifier are these for?
Appears to be cathode biased, so there's a good chance the 6P3S-E's will be running way too hot in your amp.Raven blackhawk
