One word... Guardrails...Pickers of nits, AI is still a toddler, it will just keep "learning and improving![]()
I suppose if you put into the software, “use a Technics 1200 turntable,” the image may have been more accurate. And have “the table turned 180 degrees.”This was another promo picture I created with some relevant text. I had to cut out and warp the eagles album cover to make the stack relevant (My band plays some of their stuff). One thing interesting about these Ai generated pictures is it demostrates that Ai does not know the functionality of what is actually in the pictures. Notice it does a poor job of replicating turntables because it doesn't really know how they are used, nor what they actually are.
Yeah. I posted photos of the band too. In fact, I don't even bother with Ai stuff any more. It was fun but just seems too fake.I suppose if you put into the software, “use a Technics 1200 turntable,” the image may have been more accurate. And have “the table turned 180 degrees.”
Did you post any actual photos of the band? You don’t need to post them here, as that might make you vulnerable to AI scraping software (life is full of irony, no?).
Yikes, I’m not sure I want to know.Puzzled at what the "Loudbags" switch does...
so I actually poked a bit at this. It ends up operating at a not-happy place. It should be running something like double the current and the plate resistors are about 3x what makes sense. For yucks I tried to get it to fix it, and it spit out a completely unworkable design where one of the outputs was actually connected to ground.I plugged some stuff into Google's AI to see if it came up with a workable schematic for something. I asked it to give me a schematic using the triode sections of a pair of 6LR8 tubes to create a floating paraphase inverter with a 250 volt supply. What it spit out doesn't seem completely unreasonable. I think the plate and cathode resistors may be high enough to bias it too low but I've made no particular effort to verify it.
It can't actually draw a schematic but I got the gist of it. I'll verify whenever I pick up tubes for this.
I posted these pictures in another thread, from what I remember, this amp was for sale on eBay with AI generated pics
I saw this AI generated slop this morning. Just wondering how it would sound?
The woofer would sound like a tweeter (or as much as it could) with that 10uF cap in series.
The midrange wouldn't work at all, as the green wire has no path (direct or indirect) back to the +ve red terminal.
The tweeter would work, but not for long since the 2.2R resistor will let low frequencies through.
and this is why you always check what anything on the magic internet box returns. I've seen things drawn by real humans that were grossly wrong too. Heck, I've even seen drawings made decades ago by reputable companies (Sams) that were just not correct in some fashion.FAIL
Spookers huh LOL
