groucho69
Member
if you remove the screws, then you need to gentle work their way our with your hands. Alternatively, you may be able to remove the solder, using solder wick or a solder pump to remove the board while leaving the mosfets mounted on the heatsink. If you put any wedge between the back of the transistor and the silicone pad, then you will puncture the silicone and this will need to be replaced. If you want to go down to the bottom of the issue with this unit, then don't worry too much about the silicone pad. Just get the transistors out and test them. They can not be tested in circuit.
You will also have to test the source resistors (the 0.47Ohms ceramic resistors next to the mosfets). And also check the gate resistors which are the 1K resistors that connect to pin 1 of the mosfets.
Do you really think I'd forget to remove the screws? I'll never make that mistake...again. LOL
