They can be bi-amped with a few modifications!RS-2 or RS-II? Both exist, but neither is bi-ampable
Which are not trivial; you're talking about essentially redesigning the crossovers, and also the mounting plates to support two sets of (good, unlike the originals) binding posts, with four stiff, heavy cables plugged into them as there is no way the flimsy factory plates will support that kind of mechanical stress.They can be bi-amped with a few modifications!
If you do it, post a write-up with plenty of pictures and your listening impressions.
I’m talking about using an external active 3 way crossover and completely bypassing or removing the original passive crossover’s.Which are not trivial; you're talking about essentially redesigning the crossovers, and also the mounting plates to support two sets of (good, unlike the originals) binding posts, with four stiff, heavy cables plugged into them as there is no way the flimsy factory plates will support that kind of mechanical stress.
That's for the RS-II, and I too recall something about that mod being done in the past. In any event it's doable, and yes:
When I redid the crossovers in my RS-IIs I split them to allow for biamping. That said, I haven't biamped. I do biwire, but my Parasound HCA-2200ii has plenty of power.Which?
I think I recall someone modding a pair of RS-IIs for bi- amping, but it's been a long time since I saw that and I could be misremembering.
In addition to the different crossover points for the woofers each one is in it's own chamber with a different volume. The one being low passed at 60HZ is really operating more like a sub-woofer.This crossover is pretty complex. The two woofers have different low-pass cutoffs, and then the upper and lower mids have lower upper crossover points than the center mid. Going with a three way crossover will result in a bit more upper bass and more upper mid. Might be hard to get a balanced frequency response.
I've actually been looking at those active crossovers for a future speaker project. Thinking about using one instead of having to design and build a passive crossover.I have one of these K-231’s hooked up with some other bi amp able speakers and it works pretty awesome so that’s how the wheels started spinning on trying to bi amp my RS ll’s
I removed the original crossovers and temporarily wired it up to the K-231 to test it outI did rewire mine to be bi-amped but I just split the crossover and added a second set of binding posts. I'll try to dig up the pictures I took and post them.
and it’s sounding awesome already.I still need to make a particleboard back with two sets of speaker jacks installed.Those are just temporary until I get the back cover madeThey ought to start making rhodium-plated audiophile Wagos![]()
Those wago’s are pretty handy thoughThose are just temporary until I get the back cover made
Oh I know I use them all the timeThose wago’s are pretty handy though
How did you adjust the crossover points of the K-231 to match the crossover frequency for all the different crossover points? When I looked into that unit a while back I was under the impression you had to request "chips" that get installed to set the crossover points and changing them required buying different chips. How did you address the different crossover points for the woofers and the different points for the top and bottom mids vs. the center one?I removed the original crossovers and temporarily wired it up to the K-231 to test it out
That's my understanding as well. And charging $12 to modify any crossover point doesn't exactly encourage experimentation.I was under the impression you had to request "chips" that get installed to set the crossover points and changing them required buying different chips.
Good point. RS-II are, technically at least, 5-way speakersHow did you address the different crossover points for the woofers and the different points for the top and bottom mids vs. the center one?
$12 a module isn’t that expensive to me.That's my understanding as well. And charging $12 to modify any crossover point doesn't exactly encourage experimentation.
