The Yamaha P2250 is a great amp but specs says 175wpc @ 8 ohm and 250wpc @ 4 ohm so maybe not the best candidate to drive difficult loads.
A "high current" amp is a must to drive low impedance speakers. Rule of thumb says that a high current amp doubles power when impedance is halved, ie 100wpc @ 8 ohm becomes 200wpc @ 4 ohm becomes 400wpc @ 2 ohm and, for a select few, 800wpc @ 1 ohm. Very very few amps double into 1 ohm - some Krell and Accuphase off the top of my head, but there are a few others and of course amps with autoformer outputs like McIntosh.
It makes sense because Ohm's law says that current equals voltage divided by resistance. Voltage remains constant regardless of impedance, so it follows that when speakers' impedance is halved amps have to deliver double the current, and most of them don't have the power supply to do that.
For sure the Yamaha would work fine at moderate listening levels, but it might run into trouble at high SPL. On the bright side, since it's a pro amp it has some kind of overcurrent protection so it's unlikely to sustain any damage; however, a clipping amp can damage speaker drivers.
