I found a nice
Pioneer DVL-919 which is a DVD/LD player
(1) DVD/LD/LD-G/Video CD/CD/CD-G/CDV Full Compatible Playback
(2) High Quality Sound 96kHz/24-bit D/A Converter
96kHz/24-bit DAC wide-band technology is applied to offer superb 24-bit resolution, and sampling at a rate of up to 96kHz to
exhibit a superior hi-response and perfect reproduction of the original sound quality of 96kHz/24bit data recorded DVD discs.
(3) 10bit High Accuracy NTSC Encoder & 10bit Video DAC IC
The NTSC Encoder and Video DAC (digital to analogue converter) IC will provide a consistent D/A conversion process of 10bit
video data into equivalent analogue signals to result in a high picture quality.
(4) Legato Link Conversion
The CD and DVD recording process cuts off signals bellow 16 and 20-bits, increasing quantization noise and creating a jagged
waveform, so that the reproduced sound is different from the original. The built in a Legato Link Conversion processor will restore
the lost signals by expanding the original waveform using DVD/CD data. This expands dynamic range up to an audible level,
smoothening waveforms to restore fidelity to the original sound, in all of its naturalism and subtlety.
(5) Two LSIs for High Quality Picture and Sound
By inheriting Pioneer's State-of-the-Art technologies applied in its flagship model DVD-Video player, the DV-S9, a high quality
picture and sound will be assured.
Viter-bi RF Decoder
The data processing LSI contains Pioneer's original error correction system to improve correcting ability up to a maximum 1/
several-hundred data error level, by using statically analysed parameters through RF (Radio Frequency) data reading.
AV1 Chip MPEG Decoder
The AV1 Chip MPEG Decoder combines the MPEG2 decoder and audio decoder into a single chip resulting to reproduction of a
hi-quality picture and audio with no interference to analogue signals.
(6) Other Features
Digital Accurate Servo for a stable playback
Self-Light-Up GUI Remote Controller with One-Touch Jog/Shuttle Control
Video Noise Reduction
FL Dimmer
Virtual Dolby Surround (certified by Dolby Laboratories Inc.)
Component Video Output Terminal
DTS (Digital Theatre System) Digital Audio Output Terminal
Automatic Digital Audio Output Switching
Automatic 96kHz/48kHz Output Switching
Transfer Rate Indication
Condition Memory & Replay Memory
Quick-Turn Both-Side Playback for LD
Frame and Field Step Play
