Billy Oxygen
One last modification to note. I ended up adding a mills 1% 3 ohm resistor in series with the 45 ohm resistor on both crossovers. I did this to attenuate the mid/ treble circuits. So this is with the minimal presence switch on and both the mid and tweeter connected with reverse polarity. Result no change in tonal quality, increased ability to hear the low middle and low low end a little better. I found that it is easier to hear how well defined the low end is, and a fuller mid range. I am estimating that the woofer rolls off naturally at 2500 hz.
Great speakers, to my ears they are pretty well flawless in my set up.
