EPI 100, Genesis Physics, Dynaco 25, AR 4ax / AR15, JBL Decade 16, OHM model L. Have owned all of these at one time and often at the same time. They are all good depending on your choice of material and room specs. No way to say one is better. Dynaco actual LF response is no where near the advertised 30HZ at flat response (absolutely no way!) It can have too much LF presence at times giving the impression that it is driving lower. It may touch 30hz at -9 or -12db but the OHM, EPI, Genesis would also fit that spec. Dynamic HF response of the dynaco is ok but not great. It shines in the mid bass section so female voices do sound very good on the dynaco. If comparing the EPI and Genesis make sure, as mentioned above, its the very early models with NON ferro-fluid tweeters. Ferro-fluid models have a somewhat limited HF as new and over time gets worse, much worse. Have heard 20-30 year old ferro versions of inverted dome barely hitting 10KHZ. Early model 100 and Physics however are very good. AR's always sound good especially with jazz (4ax better HF than its AR15 replacement). The Ohm with the optional SBA is very dynamic but the tweeter can be harsh. OHM improved this with the model L2 by padding down the low tweeter. The L sounds much larger than its actual size. Lots of the L owners have done the padding trick with great success as it smooths out the upper mids. The JBL decade 16 sounds more like a near field monitor to me rather than a true listening speaker but is decent in a small room.
