Surprise!!!! Sproingggg.......
That
tight friction fit between the post and the top button got WEAK!!! The assembly now does NOT float over the arm, instead the force of the big spring causes everything to bind - and tear up (formerly irreplaceable) expensive rubber on the drive motor's tire. Some early fixes tried to drive the frozen idler by increasing a spring size elsewhere, to increase the force of the motor drive tire onto the idler. Fail. Tear up that drive wheel really quick. Another fix tried to LIFT the binding surface of the botton of the idler ABOVE the arm. Fail. Still kills that drive tire.
The problem? Look at the post, there's a vertical CRACK in the post, and the part of the button that went down inside the post now just expands the post, rather than generating friction. The nylon dried out and lost some strength, and there IS a lot of tension there, so the nylon just split. The fix, a brass sleeve made out of brass tubing. Reinforces the entire post, the nylon is no longer in tension, it is in COMPRESSION. PASS.
Of course it's a lot of fun cutting something smaller than a pencil eraser, making sure the ends are square (not tilted or wobbly) and getting rid of any burrs inside which would make it impossible to get on, and any burrs on the outside that would make it impossible to get the idler B on. We're talking clearances of 0.001 inches. A lot of machining is 0.005 clearance... AND THEN, to make life miserable, KEEP from knocking the tube out of ROUND while doing all of this... fun...
but I figured it out. Die makers files, stuff like that...
BUT TANSTAAFL: there ain't no such thing as a free lunch..........
That sleeve increases the diameter of the post, and we DO get a freebie, the spring holder (green circle) clears it (edit - NOPE!! it gets bored out too because the button's outer wall expands). BUT the B idler
doesn't fit over it. OK, easy enough... open up the hole in the B idler to restore the original clearance (the RED circle) - the sleeve isn't THAT thick..... well... close but no cookie...... LOOK AT THE BUTTON, on the Left.
Here comes the HARD part.
See the "halos", the green circle with the red circle inside of it, we'll get back to them. There is a tall nub that fits INSIDE of the idler B post, THAT'S the friction fit. The green cylinder drawn above it means that not only is the diameter correct, it is the all important friction fit surface that we must PRESERVE AT ALL COSTS.
Then there's the wall around it, forming a groove that the idler B post fits into, OR USED to fit into,
until the brass sleeve was added.... OUCH.... so, options: 1. remove the wall, or 2. increase the groove's width (make that wall thinner) WITHOUT hurting the inner surface of the groove. Now we're back at the "halos", the red circle is the outer face of the groove, that must be made wider. The distance between the red halo part and the green halo part will end up being 0.008 inch (
eight thousandths of an inch ) when I'm done cutting..... So, I made another tool. It was a real %^$#^%%^%$ to make.... If I ever have a fire, I'm gonna grab that tool BEFORE the computer....
Note: the shavings around the button and in the groove are the result of stopping in the middle of the groove cutting to take a picture.
Success: this is what a good clutch looks like, the button is holding it all together without the assistance of the center shaft. So far I have done two. I will do these clutches like I do the STV-2H, STV-3H, STV-4H diodes. I get and fix the broke ones...
and this is what good versus bad looks like when on the arm, the one on the left is good, the one on the right is binding.
this picture was taken FIRST, before the clutch on the right was repaired, all the other pictures are THAT CLUTCH being repaired.... I now have NO binding clutches.
