I am going to pull the volume pot later today and do some out of circuit measurements. I found a supposedly new replacement pot that I am asking more questions on as it doesn’t have the exact same connections as the original. Will report back here what I learn. I am also going to replace all the color coded tubular’s with Jantzen 400 volt crosscaps and see if that helps anything. They are all easy to get to and I can just cut the originals outBe curious how that works out for you. Mine has the same issue...
I have not worked on that amp, but my advice is to get rid of those black capacitors with the color bands indicating their capacitance values. They end to leak (small DC currents, not liquids, since they contain none). Sometimes the cases develop cracks in them as well.I just brought this Citation 1 back from the dead. Having a problem with the loudness (volume) pot. Anyone successfully rebuild one?
All the 0.1uf’s have been replaced. It’s either the balance or the volume and would put $100 on the volumelooking closer at the schematic, this also has local feedback loops around many of the tube sections in the line stage. If those resistors are off, the gain will be off side to side. A bad volume pot tends to have tracking problems, it will shift the balance side to side as you change it. If the feedback resistors are off, it will just be skewed in one direction but it would be fixable with the balance control. Carbon resistors are pretty prone to drift so they would be worth checking at least in circuit and comparing side to side if they read funny because of other parts across them.
the resistors being off will also screw with how the tone controls work. This is way more complex than your average preamp, the bass and treble controls switch in and out different caps and resistors rather than just using pots to do it.
It’s all over the place and there are bad spots and you can feel it slightly bind while turning.is it consistently shifted to one side or does it wander as you turn the volume up?
It’s been flushed with F5 multiple timesIt’s all over the place and there are bad spots and you can feel it slightly bind while turning.
